View Poll Results: For those lowering, which option will you choose? | |||
Lowering Springs | 13 | 19.40% | |
Height Adjustable Springs | 43 | 64.18% | |
Coilovers | 11 | 16.42% | |
Voters: 67. You may not vote on this poll |
06-03-2023, 07:46 PM | #1 |
Rep 1,354
Suspension Experts
OK guys, I am needing some help on suspension. I was wanting to know, for those who will be lowering their cars, how will you do it and why did you make that choice? What are the pros and cons of each?
06-03-2023, 11:40 PM | #2 |
Rep 1,691
It's a complex topic, so this is going to be a simplistic answer.
Just straight lowered springs commit you to one height, I do not recommend. They do improve the look and firm up handling. HAS improve the look and street driving and are adjustable unlike springs. They are worth the extra cost over non-adjustable springs, IMO of course. Good coilovers can be expensive AF but can really upgrade the handling of the car, and let you tune things like rebound rate. They make sense if you are going to track your car and drive at an expert level. (While cheap non-adustable coilovers exist, I have no idea why you'd ever buy them.) For most people, who just want to lower their car and get mild handling improvement, HAS makes the most sense for cost. For experts, there are coilovers. |
Ronin761441.50 Kevin_The_Clean14144.50 ourlee1536.00 SebG87277.00 LCDRJohn624.00 ///M TOWN32295.50 MineralGreyMetallic1081.00 Geighty72691.50 |
06-03-2023, 11:42 PM | #3 |
Rep 1,691
06-03-2023, 11:56 PM | #4 | |
Rep 3,655
For those looking to mildly lower and improve driving/handling, especially on the streets, lowering springs makes the most sense and is most economical. |
06-04-2023, 12:05 AM | #5 | |
Rep 1,354
06-04-2023, 12:28 AM | #6 | |
Rep 3,655
Granted, any part can fail for any reason but this is a true M suspension to begin with. The H&R Sport Springs should not cause any issues. Sure, you can go with H&R adjustable or coils, KW coils or a similar high performance setup but your rude will be quite stiff and a little much if looking for daily driving ot performance on the street. If its a ture, all out track car, go for the gusto. |
06-04-2023, 07:53 AM | #7 | |
Rep 1,609
I have no plans to modify my car's suspension but if I did I'd search out a set of lowering springs and shocks (struts) designed to work with the springs. |
Ronin761441.50 |
06-04-2023, 08:42 AM | #8 | |
Rep 1,508
Can you all post up what brands you dig the most? |
06-04-2023, 09:18 AM | #9 |
Rep 1,354
Lowering Springs for an M4 - $378 https://www.ecstuning.com/b-h-and-r-...et/28616-4~hr/ KW Height Adjustable Lowering Springs - $1,134 https://www.ecstuning.com/b-kw-suspe...p/253200eb~kw/ KW Coilover V3 Kit - $3,594 https://www.ecstuning.com/b-kw-suspe...t/352200eq~kw/ Please note that these prices are for the M4. The G87 options were rather linited. I just ised these just for illustrative purposes only. |
06-04-2023, 09:28 AM | #10 | |
Rep 90
I was also checking some options and I finally will go for springs in first place and then, eventually, coilovers. Springs PROs: cheapest option (about 350€ if you go for Eibach or HR w/o labour), fixes the look, ride quality is similar to stock. CONs: no adjustment HAS PROs: height adjustment to get the perfect fitment. CONs: price (you range from 800€ KW or HR to 1900€ M Performance w/o labour) Coilovers PROs: Taylor made option, potentially perfect for road and track, really changes the dynamics of the vehicle. CONs: price (You go from 3.000€ of the KW V3 or Bilstein to above 8k€ w/o labour which will be more expensive than the other option). But to be honest, instead of the HAS I would go the extra mile and do the coilovers. Just my view though, hope it helps 😁 |
Ronin761441.50 |
06-04-2023, 09:40 AM | #11 | |
Rep 3,655
A lot of these are still in different stages of R&D, final design and production for the G87 M2. Some may also ve available to their "authorized" vendors/installers. For those who say the HAS is better than lowering springs, other than the ability to adjust the height, please explain what you feel the difference is (I have the H&R adjustable on my B9 S5 since January 2018 (car purchased in December 2017) and have never adjusted them from the initial setting we used when installed...only went with them as that was the only spring available for the car at the time). If going with companies such as H&R or KW, they do R&D on each specific car to produce a product that works properly for each specific model car, they are not just a generic made spring vased on what is posted in a car's user manual or manufacturer's OEM part spec sheet. I have had cars with ARK DTP and KW Var 2 coils on street cars (not for track use) and they are very stiff and for a car that doesn't or wont see the track, they are a bit uncomfortable and unforgiving in the ride feel. Just providing my 2 pennies, not stating you have to or should go in any direction other than what you, the owner and user, feel is right and best for you. |
06-04-2023, 09:50 AM | #12 | |
Rep 1,354
06-04-2023, 10:17 AM | #14 | |
Rep 1,354
How much wear is anyone's guess. Many people use them and some who would prefer not to, still use them. I guess if they are not too large they would be OK. I believe if you use hub centric spacers are pretty good. The right way to have your wheels pushed further out would be to get wheels that have an offset that accomplishes this without spacers. The downside of that...buying new wheels LOL. There is always a catch in everything you do. It is just a matter how much risk or wear and tear you are willing to take. Many people use lowering springs and spacers and are happy with them so I do not think they are bad. All personal preference. |
SebG87277.00 |
06-04-2023, 12:34 PM | #15 |
this is the way
20015
Rep 8,949
Before I get into the pros and cons I need to point out that quality products are essential when modifying your suspension. You want ones from reputable manufacturers that are specifically designed for your car and you want ones with spring rates that are matched to the OEM dampers if using lowering springs or a HAS kit. If you buy something that isn't from a reputable brand and hasn't had the proper R&D for the G87 and have clunking noises, blown out struts/shocks, etc. that's on you! I'm also not going to get into the cost of installing each type, they all involve more or less the same amount of work so the cost delta between installing each type isn't that big. Now that that's out of the way let's get to work!
Lowering Springs
HAS Kits *Note: If anyone wants a detailed explanation of how HAS kits work you can checkout this writeup I posted here.
Coilovers
12
06-04-2023, 01:03 PM | #16 | |
Rep 1,354
06-04-2023, 01:38 PM | #17 |
Rep 3,848
best to pair the right spring with the right shock. lowering springs are cheaper and look better than oem, but your ride quality/handling will be better when its paired with the right shock. Your oem shocks will wear out faster with a lowering spring.
another thing to consider is that if you're paying a shop do to lowering springs, they have to pull the shocks out anyway
2018 Porsche GT3 6MT Previous: Ferrari 458 | R35 GTR | F80 M3 | F87 M2c | E46 M3 | E36 M3 | Scion FRS |
Ronin761441.50 kimchee411102.50 |
06-04-2023, 02:25 PM | #18 | |
Rep 3,655
You do realize H&R and KW, for example, do R&D with the actual car to ensure their springs ARE matched with the car's OEM components. |
Squidget3813.00 |
06-04-2023, 03:29 PM | #19 | |
Rep 1,691
Or maybe you are worried you'll get the ride height wrong if you buy springs. HAS lets you try different heights until you find your perfect setup. |
06-04-2023, 03:36 PM | #20 | |
Rep 1,354
06-04-2023, 03:50 PM | #21 |
Rep 1,691
To be clear, I don't have a strong opinion. Everyone's circumstances are different, every option is right for someone.
I do however, totally agree with Rob that no matter what option you choose, don't cheap out. Get a well-engineered option from a reputable vendor. |
06-04-2023, 05:25 PM | #22 | |
Rep 3,848
you may have a slight improvement in lap time. but you can have that and ride comfort with a proper coil over setup.
stashstein254.00 |
