06-04-2023, 01:13 PM | #1 |
Rep 91
Replacement windshield fluid cap
I'm dressing up my engine and wanted to know if there is a billet blue windshield fluid cap out there...
06-04-2023, 01:36 PM | #2 |
Rep 471
Drives: G20 330i xDrive M-Sport
Subb’d because I haven’t been able to find one. The G8x used a different neck and cap. The F30 is larger and fits over the neck in a way that doesn’t seal. I believe with some modification (an inner gasket of some kind) the F30 could be made to work.
Printertom161.00 |
06-05-2023, 08:16 AM | #4 |
No 55mph
1622
Rep 8,477
I used the Blackline Caps from GoldenWrench Supply on our Portimau Blue M440
IDK if the M340 has the same style as the 440, but the Cap for G8x series fits perfectly. You simply remove the OEM cap and the aluminum one has an o-ring and installs/seals into the neck perfectly
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
07-05-2023, 07:35 AM | #7 |
Rep 361
Drives: 2021 M340i xDrive
07-06-2023, 06:41 AM | #8 | |
Rep 471
1QuikWS61621.50 |
07-13-2023, 12:24 PM | #9 |
Rep 67
02-27-2024, 08:03 AM | #10 |
Rep 91
