BMW 2 Series Technical Topics (G42) Wheels / Tires
      06-04-2023, 08:29 PM   #1
TheGeekGuy
Drives: BMW M240i
Stud Conversion - G42 M240i
Does anyone know where I can get a set of studs to convert a G42? All the ones I see either don't look right, or are just bolts.
2023 BMW M240i - Lady Neith
Gone but not forgotten:
2021 MINI JCW GP • 2016 MINI JCW • 2012 MINI Couper S • 2010 MINI Cooper S Camden Edition
      06-05-2023, 01:31 AM   #2
Kaolinite
Drives: 2022 m240i xdrive
https://motorsporthardware.com/produ...eel-stud-kits/
      06-05-2023, 09:34 AM   #3
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Can someone please explain what 'stud conversion' means?
      06-05-2023, 09:48 AM   #4
rons e92
60-130 Enthusiast
rons e92's Avatar
I ran the Macht Schnell 75mm stud conversion kit on my car. Worked great with the 10mm Dinan spacers I had before I switched to Apex VS5RS wheels.
Just a note, I took them off the car. Studs are great, but if you have anyone with a pneumatic impact anywhere near your wheels, I would advise against using studs.
I had to remove mine because the idiots at the tire shop completely destroyed them with the impact gun. The studs were coming out with the nuts. There are specific torque values and an impact gun completely negates all of that.
I'd like to run studs again, but to spent $200 for another set just to have them get destroyed by some careless idiot with an impact gun doesn't appeal to me.
      06-05-2023, 09:50 AM   #5
rons e92
60-130 Enthusiast
rons e92's Avatar
From factory BMWs use lugs to hold the wheel to the hub. These are basically big screws that go through the holes in the wheel and thread into the hub assembly.
A stud conversion replaces those bolts with threaded studs. You screw the threaded stud into the holes on the hub, then you put your wheel into the studs, then screw it down with lug nuts.
It makes taking the wheels off and putting them on easier and they have less risk of hitting your wheel into your rotor. They also look cool, which is why I had them.
      06-09-2023, 03:45 PM   #6
Pentland
Drives: BMW M240i (G42)
If that’s the only reason, you’d be far cheaper buying a pair of stud alignment pins which, to be fair, you should have anyway
      06-16-2023, 01:46 PM   #7
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
The motorsport studs are crap. The metal is soft and will rust quickly, the coating is a joke. I received them, many of them had damaged threads, sent them right back. These are like Harbor Freight quality. Stay with the OEM, way better.
I use the alignment pins, super easy. https://www.amazon.com/dp/B01L2WE1JK...roduct_details
      06-16-2023, 02:36 PM   #8
Prince Thundernight
And this is the size to fit G42?
      06-17-2023, 05:12 PM   #9
Pentland
Yes.
      06-17-2023, 05:44 PM   #10
Prince Thundernight
Originally Posted by Pentland View Post
Yes.
Already in my cart…
2023 G42 ///M 240i xDrive Thundernight Metallic
