06-07-2023, 08:00 AM | #1 |
Rep 666
left xenon projector is loose, any ways to put it back in place?
so i found out that the projector xenon is loose in one of my headlight. if you see my pic, the right headlight is perfect, the black ring on the projector is perfect, but the left headlight black ring is projected a bit up as you can see the top black ring is covered by the headlight eye brow
now my left headlight level is way too high as you can see from the beam... is there any way to fix this? or i am out of luck, and have to buy new headlight? thanks. |
06-07-2023, 08:30 AM | #2 |
Rep 482
Is it loose loose (light beam shakes and "wonders" under vibration from driving) or is just pointing up? - May be you have a damaged leveling mechanism inside the headlight? Have you tried manual height adjustment screw at the back?
See if you can locate a yellow hex for Allen key per pic here: https://www.bimmerfest.com/threads/a...369828&slide=0
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
06-07-2023, 09:27 AM | #3 | |
Rep 666
02-12-2024, 02:34 PM | #4 | |
Rep 1
