      06-16-2023, 12:42 PM   #1
bcf e93
Drives: 08 e93 18 M3CS
F80 CS
Hello, I just purchased a M3 CS. Can I install a leather m sport steering wheel ?Thanks
      06-16-2023, 12:57 PM   #2
swagon
swagon's Avatar
Drives: F80 6MT
yes
      06-16-2023, 01:08 PM   #3
bcf e93
Does it matter if I buy heated or not? 323050? 32-30-7-847-607? 606? Do all of my trim pieces transfer to the new wheel? Thanks
      06-16-2023, 01:25 PM   #4
EezyBeezy
EezyBeezy's Avatar
289
Drives: 2018 BMW F[am]80 M3
It'll matter if yours came equipped with a heated steering wheel and want to retain it. If you don't care for it then you are good to go.
      06-16-2023, 01:49 PM   #5
bcf e93
Thank you, no heat.
      07-02-2023, 12:15 PM   #6
bcf e93
Hi, I have a couple additional questions, when I swap out the steering wheel, does any coding need to be done? Is this a diy project or should I have it done professionally? Thanks
      07-02-2023, 01:20 PM   #7
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
No coding is needed. Just make sure you disconnect the battery before you start your installation. Otherwise your airbag may go off.
BMWCCA member Puget Sound Chapter
FSHNGRY2562.50
      07-02-2023, 02:20 PM   #8
bcf e93
Thank you. I'm going to give the oem wheel some time, see if my opinion changes. It's so much different from my 911
