BMW 2 Series Technical Topics (G42) Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      06-17-2023, 06:52 PM   #1
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Fuel grade
I致e searched the forum, and haven稚 found an answer, but I assume the B58 requires top grade juice?
2023 G42 ///M 240i xDrive Thundernight Metallic
覧覧覧覧覧覧覧覧覧覧覧覧
      06-17-2023, 08:11 PM   #2
yordmech
yordmech's Avatar
44
Drives: 2022 BMW M240i xDrive
AKI 91 is the recommended fuel for it. Manual states that it can also accept AKI 89 if no higher options are available but should be avoided and may cause engine knock.
Sonic RR166.50
      06-17-2023, 08:14 PM   #3
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
Most higher performance cars require 91+. Ideally top tier gas.
Sonic RR166.50
      06-17-2023, 08:55 PM   #4
yordmech
yordmech's Avatar
44
Are you 100% on this?
I find it odd that the B58 has a higher requirement for minimum octane rating than the S58
Added screenshot from the manual. Also the inside of the gas cap lists the same. (Note: The sticker is not factory equipment)
      06-18-2023, 09:19 AM   #5
Prince Thundernight
Some really great answers, thanks.
覧覧覧覧覧覧覧覧覧覧覧覧
c1pher5034.00
