06-20-2023, 08:05 AM | #1 |
Rep 5,399
F30 N55 Fuel Injectors: EU5 vs EU6?
It appears that F3x N55 engines either came stock with EU6 fuel injectors or with the higher flow EU5 injectors. Does anyone know if there is a reason why?
My 2015 335ix probably has the EU6 injectors that I’m about to replace to ward off some leaks. I was told that the flow of the EU6 is more than enough for an N55 engine upgraded to E85 with a Pure500 turbo upgrade (500+ hp). If that’s true, is there any other reason to upgrade to the higher flow EU5 injectors? Is more flow the only difference between them? Different spray pattern? more reliable? Better for higher HP? Handles E85 better?Any reason at all? Cost isn’t really an issue, only $56 more total. Thanks! |
06-20-2023, 11:39 AM | #2 | |
Rep 176
https://www.fcpeuro.com/products/bmw...h-0261500136kt https://www.fcpeuro.com/products/bmw...-13647639994kt You will be fine with eu6 injectors for a pure500.You'll run out of turbo before you do injector. EU5 or upgraded injectors are really only needed for 600+whp. I've been running EU6 injectors for 3 years on a pure stage 2 and E50.
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
johnung4537.00 |
06-21-2023, 07:05 AM | #3 | |
Rep 5,399
1) I wonder if one spray pattern is more beneficial than another, and 2) I wonder if EU6 or EU5 is more reliable/less prone to leaks? My reason for replacing injectors now is: 1) the many comments that I’ve read about leaking injectors causing damage, 2) I have a symptom when my tank has >E50 and the car sits all night, in the morning it has great difficulty starting, as if the engine is flooded. As the ambient temperature drops it gets worse. Been told that a slow leak from an injector will flood the cylinder overnight. To change from a non-stock injector is it just simple coding in E-Sys or ISTA?. |
06-21-2023, 02:57 PM | #4 | |
Rep 7,622
06-21-2023, 05:19 PM | #5 | |
Rep 5,399
There was a discussion about it and a method of troubleshooting by pulling the spark plugs was suggested. But I’m having some other work done so I’m just going to replace the whole set of injectors and be done with it. |
06-21-2023, 06:08 PM | #6 | |
Rep 7,622
06-21-2023, 06:19 PM | #7 |
Rep 5,399
I wouldn’t think so. It’s just physics. I learned pretty quickly the first winter that I had FlexFuel capability, not to run higher than E50 in the tank. It was a pain in the neck to have some warm days forecasted, put in E85 to collect some engine logs and then have the temperature drop suddenly.
06-21-2023, 06:26 PM | #8 | |
Rep 7,622
06-21-2023, 06:30 PM | #9 |
Rep 5,399
Oh no. I think I misread your comment. I thought you were saying new injectors might clear up normal E85 cold start up issues, not just leaky injector. My bad
