Will battery die if car inactive for 2 weeks?
07-10-2005, 04:23 AM | #1 |
Rep 91
Hi guys,
Just posted the same question at bimmerfest forum as well, but here's the question: I will be leaving town for 2 weeks straight. I read somewhere that BMW are meant to be driven every couple of days or the battery will be drained. Something to do with all the I-drive electronics or stuff thingy-hicky (not very technical sorry!) So if I leave for that long, do I come home and be greeted with a dead car that won't start? I also heard that it may be dangerous to jumpstart a car, that it will damage the sensitive electronics, but rather I should invest in a battery charger. So, what should I do to prep my car before leaving? Any help is appreciated! Thanks |
07-10-2005, 04:37 AM | #2 |
Rep 10,185
The E90 includes a Intelegent Battery Sensor, should the battery drain down to a level where there is just enough pwer to start the engine left, the system will cut off all sources requiring power untill you put the key in the car
So you will always have enough power to start the car But it shouldnt drain that far down in just 2 weeks Just take the car for a nice long drive before you leave to make shure the battery is totally full when you leave |
07-10-2005, 05:25 AM | #3 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
although it is not the same, i have left my e36 and e46 in my garage for about 2 weeks a few times while my family and i went on holidays.
i had no trouble starting the car after that time. i trust it will be the same for the e90. enjoy your time away.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
07-10-2005, 05:37 AM | #4 | |
Rep 899
Drives: F90 M5
07-10-2005, 07:58 AM | #5 | |
Administrator
41276
Rep 21,247
http://www.e90post.com/forums/showthread.php?t=1399 |
07-10-2005, 12:04 PM | #7 | |
Rep 10,185
Will try and find out more |
07-10-2005, 12:05 PM | #8 | |
Rep 10,185
07-10-2005, 12:15 PM | #9 |
Rep 121
If they actually have this battery saver technology, it doesn't work very well. I showed up at my dealer a few weeks ago to test drive a 330, and he said we couldn't drive it because the battery was dead. Apparently it had been sitting in the show room and not been driven in a while.
They tried to quick-charge it, and that failed to. I ended up coming back the next day - he said they ended up putting a new battery in. |
07-10-2005, 12:19 PM | #10 |
Rep 354
i let my e30 sit for over 4 weeks when we were on vacation, and it started right up!!
if you disconect wouldent you have to put in a code somewhere to get the radio or something workin? |
07-10-2005, 05:07 PM | #11 |
Rep 48
i think you will be fine,just make sure the battery is fully charged before you leave.
I once left my E46 in my garage for 3 months when I were on vacation.when i came back,it started right away.I also checked tire pressure,the result is perfectly normal .so you really don't have to worry about anything.just enjoy your vacation. :rocks: |
07-10-2005, 07:30 PM | #12 |
Rep 91
Thanks for the info guys, I will definitely take the car out for a nice long drive before leaving..
I think I read somewhere in the car manual about not putting the car into "Park" but rather put it in "Drive" when parking the car for extended periods of time. Not sure if this is necessary... although in Park, there's an amber LED right next to the P that stays on.. Any ideas? |
08-08-2005, 10:37 PM | #13 |
Rep 48
Easy way to disconnect battery
What is the best way to disconnect the battery.
Why BMW and other car companies don't place a switch near the battery to disconnect it without removing any cables. This also would be helpful when you need to repair something in the car. Also it could be nice to have a display near the battery to see how much percentage the battery have, that display could be nicer in the main display, but a mini display near the battery would be helpful in some cases and very cheap for car companies, right now if your battery is very low on power, you can't know how much battery power is left. Also I don't understand why the car companies don't place a monitor to check the percentage of the battery to avoid not starting the car, when the battery is less than 60% or the needed amount of power to start the car, then all the accessories stop working, why would anyone wants to leave the lights of their cars until the car won't start, or hear the radio for long hours without turning on the engine? The only car company that thinks in this problem is Rolls Royce, they place two batteries on their cars to avoid not starting the car if you leave the lights or hear the radio for long hours. |
04-21-2006, 06:26 PM | #15 |
Rep 247
evoq MBZ also has 2 batteries on some of their higher models...
I just left my e90 for 2 weeks without moving.. no problem on start up but i dont have comfort access, that to me would drain the most for sitting... and i dont have the alarm with the blinking lights. ~fk |
04-21-2006, 10:08 PM | #16 |
Rep 5
Mine has both comfort access AND alarm.
But car was only parked for 7 hours before battery went dead. No, no lights on and iDrive was off as the car was locked from outside. |
04-22-2006, 12:13 AM | #17 |
Fee
13
Rep 249
Drives: F82 SO M4
I can safely tell you that I put my baby on ice for the more than 8 weeks without turning it on and it was fine.
Fee |
04-22-2006, 12:55 AM | #18 | |
Rep 506
anyway back on topic, i've left my previous car over 3 months and it started without a problem. i don't think u have anything to worry about at all. |
