07-04-2023, 09:24 AM | #1 |
Rep 8
N55 Misfire Issues
I have a 2014 BMW 435i xDrive with 28k miles on it. I purchased it about 1 year ago with only 18k miles on it. Since purchasing it I have done the following mods:
BMS Charge Pipe BMS Performance Intake MAD Race Intercooler FTP Boost Pipe CTS Turbo Catted Downpipe BM3 Stage 2 Tune The car has been running great. The only CEL code I got was shortly after the downpipe was installed. It was for 128901 Lambdasonde 1 Bank 1, dynamics: slow response. I cleared the code and never had any issues after that (March 2023) Yesterday, while trying to pass a slow car my car stuttered, lost power and went into drive train malfunction. I pulled over in a parking lot to read the codes. 123511 Electric Wastegate, wastegate flap: stiff 140402 Combustion misfires, cylinder 4: harmful to exhaust gases after starting 140002 Combustion misfires, several cylinders: harmful to exhaust gases after starting 140401 Combustion misfires, cylinder 4: Injection is switched off 140001 Misfires, multiple cylinders, Injection is switched off 140410 Misfires, cylinder 4: detected 140010 Misfires, multiple cylinders: detected 140011 Combustion misfires: Injection shutdown Inactive 231501 - Error log entry: send buffer full I replaced all the spark plugs and ignition coils and cleared the codes. I also flashed back to the stock tune. The car no longer goes into drive train malfunction and does not throw any CEL codes but does not run right. The car has a rough idle and stutters/jerks when I accelerate. During idle, I pulled the MAF sensor plug which results in a CEL and no change to the rough idle. The codes indicate I have a misfire in cylinders 2 and 6. I tried swapping coils and always get the same misfires on 2 and 6. Could this be an injector issue? Any help is appreciated. Thanks! |
07-04-2023, 10:35 AM | #2 | |
@_sunbish
284
Rep 611
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
07-04-2023, 11:32 AM | #3 |
Rep 8
Yes, after replacing all spark plugs and coils the problem with 4 went away. Then 2 and 6 started misfiring. No CELs but very rough idle and stuttering when I accelerate.
07-04-2023, 12:59 PM | #4 |
Rep 779
Did you use a proper BMW spark plug socket, or a regular socket with a universal on it? There's a high chance you cracked the plug if you used the wrong socket.
07-04-2023, 03:41 PM | #6 |
Rep 779
Thin walled socket means nothing. Did you use a BMW spark plug socket that has the integrated universal joint? If you used a normal plug socket, with a detachable universal, the plugs can crack easily.
07-05-2023, 01:16 PM | #8 |
1297
Rep 3,536
You need a thin walled socked and a swivel.. you don't need the bmw one... but you need something. You can actually damaged a plug and the valve cover..
You have an issue, likely if changing everything cause a new issue it's something you did. Messed up a plug, bad connection etc etc
07-05-2023, 07:40 PM | #9 |
Rep 8
LA1Z24 and n55david - Thank you both for the help. I purchased a universal joint and 2 new spark plugs. I installed them with the universal joint and that fixed the problem.
There were no physical cracks or damage on the other plugs but I must have damaged them when I installed them without the universal joint. My car is running great again. Thanks again! |
09-16-2023, 11:05 PM | #10 |
Rep 3
hi i got the same issues well when i start my car up the rpm goes up to 2k and drops down and the car stalls getting misfire codes as well
101F01 - Air mass system, plausibility: calculated air volumes in air intake system implausible. 108001 - Intake air temperature sensor, electrical: Short circuit to B+. 118002 - Mixture control: Fuel-air mixture too rich. Knowledg 140002 - Combustion misfires, several cylinders: Damaging exhaust gas after starting up. 140010 - Combustion misfires, several cylinders: detected. FAQ 140302 - Combustion misfire, cylinder 3: Damaging exhaust gas after starting up. 140310 - Combustion misfire, cylinder 3: detected. 140402 - Combustion misfire, cylinder 4: Damaging exhaust gas after starting up. Connect G 140410 - Combustion misfire, cylinder 4: detected. |
09-17-2023, 02:26 PM | #11 | |
Rep 7,622
