07-10-2023, 09:35 AM | #1 |
Rep 63
ID8 Carplay GPS Bug
So there's a thread on the G42 forum on this topic, but I figured I'd start one here since someone on the G42 forum pointed out I was asking G87 questions in the wrong forum. I did a search, and it does not appear this topic is yet being discussed in our G87 forum.
To summarize the bug; If you're using navigation on your iphone (waze, maps, google, whatever have you), having the phone disconnected from Carplay works just fine, but if you connect to Carplay you inevitably end up with a bug that results in your phone GPS placing your position some distance parallel of where you really are. I've had this distance range from 200 feet to 2 miles. If you go ahead and disconnect the phone from Carplay, it returns back to normal. The vehicle's onboard GPS is never affected (I've tested this several times), but the onboard GPS directions just aren't anywhere near as good as waze/google/maps. Apparently, there is an ID8 fix already out for some vehicles, but it does not appear to be out for the G87. On the G42 forum, their issue is being fixed by update 03/2023.05. My G87 will not go beyond 03/2023.04 and it says it is up to date. Does anyone have any more information on this?? |
07-10-2023, 09:55 AM | #2 |
Rep 492
I'm assuming you are describing the bug from this thread
https://g87.bimmerpost.com/forums/sh....php?t=2019068
My Car Journey:
'07 Mazda 3 -> '16 Mustang Ecoboost -> '16 Mustang GT (MT) -> '18 Kia Stinger GT2 -> '17 Jag XE 35t + '09 Audi TT VR6 (MT) -> '17 Macan GTS + '23 M2 (MT) |
RSVP-XCI104.50 |
07-10-2023, 10:13 AM | #3 | |
Rep 63
But thanks, and yes, this is the same issue I'm experiencing. EDIT: I guess that would be because I was searching in "General Topics" Last edited by RSVP-XCI; 07-10-2023 at 11:16 AM.. |
deleted_807865_k0a0df9ee6877.50 cmgbk752671.50 |
07-10-2023, 10:40 AM | #4 | |
Rep 1,512
Drives: G87, G26, E46, Mk6 5K
I haven’t had the problem either, in either iDrive 8 car. Seems random but somewhat widespread. I’m glad as I’m reluctant to get the software update and have to reBimmercode so soon. Excited for you to be able to give it the beans later today. |
deleted_807865_k0a0df9ee6877.50 RSVP-XCI104.50 |
07-10-2023, 10:54 AM | #5 |
Rep 153
Drives: Like it's a rental!
I have this problem EVERY SINGLE TIME I get into the car. Nothing fixes it. Terribly annoying.
2022 G07 M50i, 2019 G01 30i, 2017 F25 28i
A couple of other fun cars in the current stable SOLD 2013 E93, Interlagos Blue, ZCW, ZPP, 223, 2MK, 19"s, 655, 6NR, 752, 4MY SOLD 2013 E70, Carbon Black, Cinnamon Brown, M-Sport |
RSVP-XCI104.50 |
07-10-2023, 11:16 AM | #6 |
Rep 17
Haven't driven an ID8 yet, but I had the same issue with my previous Lincoln.
When an iPhone is connected to a car with GPS feature and using Carplay, it doesn't use the location found by its GPS, but that found by the car's GPS. This bug you are seeing is due to an inaccurate in-car GPS reading. When you are experiencing this issue, you can disconnect and check the built-in navigation. It should show the same off set. IOS doesn't allow forcing to use phone's GPS reading when using Carplay, which could have solved the problem. Not sure whether there is a fix from BMW. |
RSVP-XCI104.50 |
07-10-2023, 11:21 AM | #7 | |
Rep 63
07-10-2023, 11:22 AM | #8 |
Rep 63
deleted_807865_k0a0df9ee6877.50 |
07-10-2023, 11:55 AM | #9 |
Rep 63
Just checked my settings and they are the same for Apple Maps, but Google and Waze don't have the widgets option, only "While using the app". Even still, not sure this should make a difference. I have the problem with all 3. The other day I tried driving to a place I hadn't been to using the onboard GPS. While the positioning remained accurate, it's directions just don't seem very good or clear, so I resorted to disconnecting from Carplay and popping a earbud in my ear and received directions like that. First world problem, yes, but when you're paying for a car like this, not being able to use this functionality is extremely disappointing.
07-10-2023, 01:34 PM | #10 |
Rep 163
Drives: 2024 Lucid Air, 2024 X5 50e, 1
Garage List 2003 BMW 330i [10.00]
2024 Lucid Air [10.00] 1999 BMW M3 [10.00] BMW “Zoom Edition” [10.00] 2024 BMW X5 50e [10.00] |
03/2023.05 definitely fixes the bug, my G20 updated from 11/2022.xx to the new software last month and haven't had the issue since. Supposedly the official fix was to either wait for a software upgrade or they sent out instructions to service centers on how to manually fix the issue in late April without a software update.
RSVP-XCI104.50 deleted_807865_k0a0df9ee6877.50 |
