07-10-2023, 09:21 PM | #1 |
Rep 83
Drives: 2017 BMW 440i GramCoupe
MHD Flex Fuel Kit Help
I recently bought a thr MHD ECA kit from another member. Inreceived it and when I was installing realized it isn’t compatible with the Dorch stage 1 HPFP. The fitting it came with is just 2 female ends which would be fine if I had oem or the TU pump. I was curious if anyone can confirm that the ethanol 360 fittings would work. If so, anyone know off hand what diameter is needed. The ECA sensor has bigger male end than the Dorch female line that goes to the HPFP.
https://www.bimmernetwork.com/produc...l-360-fittings Thanks in advance! |
07-10-2023, 10:52 PM | #2 |
Rep 577
My MHD Flex Fuel kit that I bought from BimmerNetwork actually came with the 360 fittings. I have a Dorch Stage 2 HPFP and everything with the install went good.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
mhowanic31.50 |
07-11-2023, 06:20 AM | #3 |
Rep 83
Gotcha. Yeah I was looking and didn’t even realize there are different kits. Shoulda paid more attention when installing the DS1. I’ll go ahead and order those. Thanks for the response!
07-11-2023, 06:56 AM | #4 |
Rep 83
Forgot to ask. It looks like precision race works has options for both 5/16” and 3/8” on the Ethanol 360 adapters. Anyone know the OEM fuel pick up size? I can’t seem to find it listed anywhere.
