07-14-2023, 08:07 AM | #1 |
Rep 17
FTP charge + boost pipe fitment Intercooler
Is it normal that the fitment is quit loose intercooler <-> chargepipe and the same for the boostpipe ?
Checked youtube but nobody is pre fitting the charge and boost pipe with the intercooler before installing https://www.veed.io/view/ba5c7e82-df...panel=showcase |
07-14-2023, 02:43 PM | #3 |
Rep 7,622
I vaguely recall that even with larger orings i had some play when test fitting on the floor. IF in doubt just go up in oring size. https://f30.bimmerpost.com/forums/sh....php?t=1659611
Nizzell33.00 |
07-16-2023, 10:07 AM | #5 |
Rep 5,386
This is why BMW and every other manufactuer uses plastic. And no, it's not an issue on the charge pipe/IC side as we've NEVER heard of a failure at this connection point on the stock charge pipe. Plastic has some flexibility and will fit tighter.
My FTP charge pipe was slightly loose on my Wagner intercooler and over time and 1000s of miles of driving, I could reach under the charge pipe/IC connection and feel oil residual which indicates not a fully tight seal. There is no major leak as there is no sound and WG duty cycles are fine. I would imagine most every metal charge pipe has this issue, most just don't know it. I just ended up taking 2" wide heavy duty electrical tape and wrapping it around the connection. Been fine for the last 3 years. I do plan to buy the revised OEM charge pipe with the far more robust CP to throttle body connection. I like the OEM CP for fitment and also lack of heat soaking. |
07-17-2023, 12:08 AM | #6 | |
1297
Rep 3,536
The oem plastic pipes are garbage and the "revised" one is garbage and still breaks and flows like shit.
07-17-2023, 01:42 AM | #7 |
Rep 17
I emailed the shop were i bought the charge + boost pipe. Showed them the video, they say it is normal it is ok...
I emailed FTP themself and showed them the video They responded " Hello sir Yes, that is normal After sealing and fitting, there will be no air leakage. Don't worry, we had all done smoke testing " So i asked them again, but it is allready sealed, you know for sure it is ok? and then they replied hello Iam also a BMW owner i know what bmw wants We are confident in our products And there is a warranty~ please check our video when the smoke fills the intercooler 1:05~1:29 |
07-17-2023, 12:15 PM | #8 | |
Rep 7,622
07-17-2023, 12:29 PM | #9 |
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
Go buy Evolution Racewerks piping and intercooler. Stuff fits nice and snug.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
07-28-2023, 10:24 AM | #11 |
BimmerPost Supporting Vendor
24358
Rep 191,163
07-28-2023, 03:41 PM | #12 |
1970
Rep 5,021
Good to hear! If you were closer I would of sent you one of ours to compare.
