Closed Thread
      07-16-2023, 11:28 AM   #1
DivergedM2
DivergedM2's Avatar
Drives: G87
BSM G87 Lowered on KW and BBS LM
Wanted to share the new wheel setup as a thread here. Lowered on KW HAS and 10/12 Macht Schnell spacers. Really changes the whole car.
Drop specs:
Front: 720mm to 687mm
Rear: 718mm to 698mm
      07-16-2023, 01:56 PM   #2
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
It looks so good. More pics please.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
      07-16-2023, 04:36 PM   #3
FryCookOnVenus
Drives: G87 (Preorder), Toyota 4Runner
Looks great!
Most fitment correction I've seen uses 12mm/15mm spacers for what people have described as a flush fit. You went with 10/12. To your eye, would you say it's flush, or were you going for something slightly more recessed than flush?
Either way, nicely done.
      07-16-2023, 07:24 PM   #4
DivergedM2
DivergedM2's Avatar
Drives: G87
Originally Posted by FryCookOnVenus View Post
Looks great!
I think for truly flush you can go 12/15.. these are slightly bigger than stock so I’d have to see if there is any rub.. I’ll def report back!
ronin130131067.00
AZG871157.50
      07-16-2023, 11:25 PM   #5
vampire81
vampire81's Avatar
Drives: '19 M2C / '19 ZL1
more photos please
spun out '
      07-17-2023, 02:11 PM   #6
DivergedM2
DivergedM2's Avatar
Drives: G87
Originally Posted by vampire81 View Post
more photos please
Haha I have quite a few
vampire81510.00
dominoM304.50
Game8134.50
ronin130131067.00
6speed_M29885.00
Motts0.00
      07-17-2023, 11:25 PM   #7
dominoM
Private Low Class
305
Drives: G87 M2 ZB 6MT
Interesting with 33 mm drop in front but only 20 in back. Is that typical to have that much difference?
      07-17-2023, 11:27 PM   #8
DivergedM2
DivergedM2's Avatar
Drives: G87
Hmm probably not so typical but I’ve heard similar setups in g80/82 setups. We purposefully left a bit in the rear to see how it settled. Once I extend the spacer size I’ll see if I can close the gap further. I personally don’t like anything close to slammed so the way it sits for me is perfect atm.
      07-17-2023, 11:31 PM   #9
dominoM
Private Low Class
305
I'm the same, want medium amount lower but not slammed. My M2 is actually in the shop RN getting HAS installed, so I'm curious how similar the front/rear will end up once things are leveled out.
Your setup looks perfect.
Closed Thread
