07-16-2023, 04:09 PM | #1 |
Rep 36
I fucked up when jacking up my car
More specifically, lowering my car.
I was working on my car, jacked it up and placed a jack stand under what i thought would be okay. Forgot to remove it and now I have a cracked pan leaking fluid. Can anyone provide some guidance on what it is, what part is it, and how fucked am I? Is it something I can replace myself and add fluid back in? Thanks. |
07-16-2023, 04:14 PM | #2 |
Rep 5,181
Broke the oil pan of your transmission. There’s a filter built into the pan and they’re easy to change. Do not start or drive your car till you fix the pan and top off with fluid. You can Google to find the YT videos.
If you’re not DIY experienced then tow to an Indy Shop for them to fix and fill.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
07-16-2023, 04:25 PM | #3 |
You got my money?
3191
Rep 4,669
Drives: Ice Cream Truck
Um... that's a big no no. Bummer man. Weve all been there. Live and learn I guess.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
07-16-2023, 04:30 PM | #4 |
Rep 551
Drives: 2022 G83 M4
Pretty sure you need this part. Honestly not too expensive of a mistake. Could have been much worse
24119504520 https://parts.bmwnorthwest.com/p/BMW...119504520.html
2022 G83 M4 Convertible Isle of Man Green on Tartufo Instagram:kermit_g83
2020 GLE 450 Emerald Green on Macchiato Beige - wife and baby mobile 2016 M3 TB on SS - gone but not forgotten |
07-16-2023, 04:38 PM | #5 |
Rep 36
Funny thing is, i knew i wasn’t supposed to put the jack stand there. As i was putting it there, i thought, “theres no way the cars coming down anyways, I’ll just leave it here”. Definitely a live and learn moment. Definitely not making this mistake again. Thanks for the input.
Do i need to replace the filter in this situation? |
07-16-2023, 04:52 PM | #7 |
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Never like to see that but it could have been worse. Hopefully you get it sorted soon.
07-16-2023, 07:54 PM | #8 | ||
Rep 781
But, how were you using the jack stands? You put a stand there but didn’t lower the car onto the stand then ‘lowered/dropped’ the car onto the jack stand? Or put the jack stand there, put load onto the jack stand then put more load by lowering the car? How many jack stands were you using? Do make sure you understand how to properly use jack stands - placement, load bearing, removal, etc. Mistakes can be deadly. |
07-16-2023, 08:15 PM | #9 |
Rep 200
On old cars with steel sumps can be done , but the use of alloy ...no . Sorry to hear that .
Needsdecaf6785.00 |
07-16-2023, 08:33 PM | #10 |
Rep 5,181
Look for a ZF8 pan kit on FCP/ECS. It comes with the pan (filter is part of the pan) and the mounting bolts (supposed 1-time use). You’ll also need a liter or three of stock trans fluid.
07-16-2023, 08:53 PM | #11 |
Rep 6,768
07-17-2023, 03:55 AM | #12 | |
Rep 36
I got excited when i finished my dinan exhaust valve install and rushed the lowering of the car. Lowered it without checking anything else underneath and put it on the jack stand. Put one side down and then went to the other side and noticed it was going down. Realized what happened and jacked it back up but it was too late. Yes, definitely a lesson learned moment -.- |
kgelfen3602269.50 TopJimmy5495.50 |
07-17-2023, 04:18 AM | #13 |
Rep 551
Drives: 2022 G83 M4
obviously it's far too late for you now but in the future the G8x has a central front jacking point that would have been a good spot for your jack stand if you were using it as a safety net like you described.
For what it's worth, I have a set of Race Ramps Wheel Cribs that I use all the time as long as I'm not pulling my wheels. That might be something you could look into as well. https://www.raceramps.com/cribs/wheel/p/rr-wc-12-2/
07-17-2023, 10:03 AM | #14 | |
Rep 781
07-17-2023, 10:07 AM | #15 | |
Rep 309
07-17-2023, 10:28 AM | #16 |
Rep 1,300
i have the 14" 2 piece supercar cribs, you don't need the supercar but i wanted the 14" and the extra wide platform is nice to have. I also have the 3" trax-jax ramps which i use in order to be able to reach the center front and rear jack points.
07-17-2023, 10:37 AM | #17 |
Rep 551
Drives: 2022 G83 M4
This is the exact ones I have. https://www.raceramps.com/cribs/wheel/p/rr-wc-14-sc-2/
The 2 piece supercar set. I like the extra Width over the regular ones and buy buying the two piece set I can put all 4 corners up on 7 inches of lift which is more than enough to get under the car. I have actually never had the car up on the full 14 inch height
1209582791.00 |
07-17-2023, 11:23 AM | #18 |
Rep 360
Atlas kwik bay. Problem solved.
2007 X3
2022 M3 Base |
Tyga113256.00 Race_Doc11464.50 |
07-17-2023, 12:22 PM | #20 |
Rep 360
Yes. If a man can love an automotive device, I love it. 42" of lift, easy up and easy down, infinite height adjustments.
2007 X3
2022 M3 Base |
Race_Doc11464.50 |
07-17-2023, 12:27 PM | #21 |
Rep 1,254
To the OP, the damage isn't too terrible. Lucikly it's a modular part that can be easily removed and replaced.
I mean, it could have been way worse! |
07-17-2023, 03:57 PM | #22 |
Rep 488
