07-20-2023, 09:04 AM | #1 |
Rep 223
f30 exhaust tips on the cheap that look good?
hey guys,
any recommends on f30 exhaust tips (any on aliexpress?) that fit well, don't look cheesy (don't stick out too much etc?) i'm sure this has been asked a million times, and no i haven't searched so feel free put me down and shame me |
07-20-2023, 05:34 PM | #2 |
Rep 482
The F3x exhaust comes with antirotation stud(s) attached to the end pipe(s), these interfere with any generic exhaust tips you can get from Ali/Amazon.
See below: You would need to modify the replacement tips or to cut off the stud(s). I chose to modify the dual tips, but had to shorten the end pipes all the way to the studs.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
07-20-2023, 06:01 PM | #3 | |
AH3 Owner
206
Rep 313
Drives: BMW 335i ActiveHybrid 3
Last I was looking at these, I believe these ones just push against the stud while not being out too far. |
07-21-2023, 07:44 AM | #5 |
Rep 482
NxTH
Agreed. These look like proper fit without alteration to the stock exhaust piping of 335/340. Dyeraudio OP has 340, so the car is dual exhaust, not like 328/330 with dual pipes on one side that do not have the studs, afaik. What you found works well for 328/330 imo, however my OCD would not rest until the CF sleeves were re-centered onto the inner pipes. This is a common problem with tips sold on Ali. I had to readjust and then to re-rivet the sleeves on my Y tips as well.
07-21-2023, 09:30 AM | #6 |
Rep 890
I've been running a set similar to these for 5+ years. They're proper slip-on tips made to fit our BMW exhausts, so you don't have to cut the exhaust pipe 'nubs' off, and are sold by various companies (Rolling Gears, SSDD, etc). Available in Black, Chrome, and Chrome Blue-tips
The quality and fit is excellent, and they've held up really well. You can also find them sold on eBay and Ali... https://www.amazon.com/dp/B0C78GGNGK/ |
07-21-2023, 09:48 AM | #7 |
Rep 5,400
I did not see dimensions at the link that you provided. Do you have length and front and rear diameters?
07-21-2023, 10:01 AM | #8 |
AH3 Owner
206
Rep 313
I don't see M-sport listed, but original is Outlet: 93mm (3.66") and Overall length : 120mm. I went to check on my original exhaust, and 120mm seems a bit too long for my liking. I would prefer 80mm from the nub.
07-21-2023, 11:13 AM | #9 |
Rep 223
07-21-2023, 11:15 AM | #10 |
Rep 223
I checked the forums and someone posted up these from ali. they slide on with no brackets/screws needed.
https://www.aliexpress.com/item/4001...1c074c4d6UcGJJ |
Oksamit78290.00 |
07-21-2023, 11:16 AM | #11 | |
AH3 Owner
206
Rep 313
07-21-2023, 11:33 AM | #12 |
Rep 890
07-21-2023, 11:35 AM | #13 |
AH3 Owner
206
Rep 313
07-21-2023, 11:47 AM | #14 |
Rep 5,400
07-21-2023, 11:52 AM | #15 |
AH3 Owner
206
Rep 313
I was merely asking if they are meant to have a hue or not, or if they are completely black. I'd actually prefer them reacting to the sun in some way.
07-21-2023, 12:16 PM | #16 | |
Rep 890
I bought 2 sets, since they were only $90/set back then, in case they ever faded/rusted/dulled — but I haven’t had to use the second set yet. (They’re stainless steel.) For care, I just wipe them down when I wash the car. I’ve never polished them… Last edited by visionaut; 07-21-2023 at 03:50 PM.. Reason: Added photo I just took to show black chrome outlets with iridescent inners, and finish :) |
NxTH205.50 |
07-21-2023, 12:46 PM | #17 | |
Rep 482
Gonna get black ones for my wife's 335 F30.
07-21-2023, 02:55 PM | #18 |
Rep 223
yeah the black angled ones look nice and seem like they fit well. and the price comes out to about $100 cad, which is reasonable. I just don't see the point in spending alot of money on something cosmetic like exhaust tips.
I'll probably order the same for mine. |
07-21-2023, 02:59 PM | #19 |
Rep 223
yeah i think that's the common issue with any of these (except maybe some uber expensive ones). what makes them wear out? the heat from the exhaust i guess? road debris kicked up from the tires?
07-21-2023, 03:38 PM | #20 |
Rep 5,400
07-21-2023, 03:58 PM | #21 |
Rep 890
07-21-2023, 04:43 PM | #22 |
Rep 482
Believe it or not, OEM chrome coated ones suffer the same faith... especially the side that is not valve controlled.
The right one on both, my wife's 2015 335 and on my 2017 340 (before replacement last year with Y tips) are pitted through the chrome coating and can not be polished out. My wife's car now has a best pair out of two sets, but will need tips' replacement probably no later than next year. I am considering black chrome OEM tips or black gloss aftermarket at 50% of price. I do like how the tips on your car look.
visionaut1320.50 |
