07-26-2023, 08:09 PM | #1 |
Rep 1,386
Dreaded WG rattle (I think)
Noticed on cold starts I had some rattling happening, it only does it around eco/comfort mode too presumably due to load (sports revving higher)
https://www.youtube.com/shorts/YnnOjNYozsI It's super inconsistent and only does it on extremely shallow revs from time to time. IIRC there's no real fix for this right; the WG flapper isn't serviceable?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
07-30-2023, 05:48 PM | #2 |
Rep 1,386
Providing this is a WG flapper rattle issue, can I just adjust the linkage rod? I had a look today and noticed it was threaded so I'm guessing adjustments can be made?
Noise is now audible when pulling away in low gears.
2015 435i - 401whp
08-04-2023, 06:32 AM | #3 |
Rep 269
I think the bolt on the rod sets the opening of the flap. The flap itself is on a centre spindle and it's that area that wears and causes the rattle. Adjusting the rod is the fix.
fortythirtyfive644.00 |
08-04-2023, 05:19 PM | #4 | |
Rep 1,386
I also have ISTA so I might try run the adjustment test to see if it notices any play.
2015 435i - 401whp
