07-27-2023, 01:30 PM | #1 |
Rep 677
I might have shorted the DME
I was working of the Reflex wiring and forgot to unplug the battery. Now there’s a bunch of codes showing up. I’m most interested in the CAN errors. Which component in ISTA can I use to diagnose? Appreciate it if you guys could give me some advises on where to start.
07-31-2023, 11:21 PM | #2 |
Rep 677
Update:
All of the error codes were caused by the Reflex. I extended the ground wire on the Reflex with a slightly thicker gauge. I guess the system didn't like it. DME CAN error codes are gone but MHD001 is still present along with 121532 - Charging pressure, ambient pressure: implausible with each other, pressure too high. 213601 - Power management: Standby current violation DME shadow codes: 121521 - Boost pressure sensor. Multiple fault. *I think it has something to do with the boost pressure and the ambient temp sensor. |
