07-29-2023, 02:32 PM | #1 |
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
Any Info on How to Run a Stage 3.5 LPFP?
Does anyone have information on how to run a stage 3.5 LPFP without melting the stock EKP? I'm going to need something to support at least 700hp on E85.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
07-29-2023, 05:13 PM | #2 | |
@lbb_kev
496
Rep 516
And what's your current setup and budget? Do you have a motiv reflex?
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
07-29-2023, 05:19 PM | #3 |
Rep 1,121
It would be the Walboro 450/525. It's Percision Racewerks 3.5 pump.
07-29-2023, 05:35 PM | #4 |
1297
Rep 3,536
Keep spare modified ekps on hand..
07-29-2023, 05:37 PM | #5 |
Rep 1,121
I was looking at the ET3 design one. Percision Racewerks says that the 3.5 doesn't need a upgraded EKP which is odd
07-29-2023, 07:04 PM | #6 | |
@lbb_kev
496
Rep 516
These routes will likely not require an upgraded EKP because the 450 (which does plug into an EKP like stock) generally plays nice with the stock EKP. That said, if you don't want to control the 525 via a Hobbs switch or motiv reflex, your other option is sourcing an aftermarket upgraded EKP that can support two pumps which will control both via CAN (OEM control) in parallel. This would be a EOS BPM4 by Torqbyte or a potentially modified EKP that has two pump outputs if that exists. I have a source for PM4s if this is what you need. One potential caveat on leaving the 525 on all of the time (which could happen if you controlled it via CAN) is that it produces a lot of amps and therefore heat. The stainless steel studs on the top hat for the 525 could potentially melt the stock plastic top hat due to its resistance. A copper stud here would help mitigate that by a lot.
07-29-2023, 07:32 PM | #7 | |
Rep 1,121
07-29-2023, 08:41 PM | #8 | |
Rep 1,117
Use the ET3 unit available from Amazon or there are posts that a new person is working with TB to rerelease their former EOS BMP4 unit. |
07-29-2023, 08:48 PM | #9 |
Rep 1,121
But isn't the ET3 just an upgrades stock EKP?
07-29-2023, 08:57 PM | #10 |
Rep 1,117
He’s made modifications to it. I purchased the EOS BPM4 2 weeks before it was offered to the public so never needed an ET3.
I have connected several heavily modded users with him pre-mass production and their unit are delivering flawlessly a year or so later. It’s the current easiest cost effective solution. Regardless what anyone tells you, I’ve seen Walbro 450 and 535 both burn up EKPS units. I’d rather not be on the side of the road and then on a flatbed for that reason. |
Boostedphil698442.00 |
07-29-2023, 09:05 PM | #11 | |
@lbb_kev
496
Rep 516
And you're right. Having that extra headroom is nice. I run a similar setup with the Dorch lift kit and Nostrum stage 2 injectors - no port injection. My PM4 is still running strong to this day supporting this 100% E85, direct injection only, 717whp setup.
07-29-2023, 09:10 PM | #12 | |
Rep 1,121
07-29-2023, 09:14 PM | #13 | |
@lbb_kev
496
Rep 516
07-29-2023, 09:19 PM | #14 | |
@lbb_kev
496
Rep 516
The ET3 Design will handle the Walbro 450 just fine. You need to figure out how you'll want to power the second pump (Walbro 525). As I mentioned earlier this secondary pump will not be controlled by the EKP.
07-29-2023, 09:20 PM | #15 | |
Rep 1,117
07-29-2023, 09:24 PM | #16 |
Rep 1,121
I agree with this. I need a solution that's electronic.
YASBBYM3594.50 |
07-29-2023, 09:26 PM | #17 | |
Rep 1,121
07-29-2023, 09:27 PM | #18 | |
Rep 1,117
The EKPS is only part of the issue. The OEM wiring and fuses are not high enough gauge to handle these higher amperage LPFPs. |
07-29-2023, 09:29 PM | #19 |
@lbb_kev
496
Rep 516
Indeed. It "works", so people on a tight budget lean towards it. The proper route is to have the secondary pump be CAN integrated via a Motiv Reflex or something like the PM4. The cool thing with the PM4 is its fault duty settings so if connection was ever lost you can limp home on a flat duty cycle setting.
If the stock ekp or ET3 ever burnt out despite the pump(s) still being good you wouldn't be able to limp home.
YASBBYM3594.50 |
07-29-2023, 09:32 PM | #20 |
@lbb_kev
496
Rep 516
I would give the product description a read again. They sell the kit with a Hobbs switch, so their "intention" is for you to run the Walbro 450 with an EKP and the Walbro 525 via a Hobbs switch.
YASBBYM3594.50 |
07-29-2023, 09:34 PM | #21 |
Rep 1,117
I’ve seen many Walbro 450s not to mention 535s take out a EKPS or worse.
-Eidos495.50 Boostedphil698442.00 |
07-29-2023, 09:50 PM | #22 | |
@lbb_kev
496
Rep 516
If the low side every goes out while you're driving you're literally shit out of luck and the car will die on you. Not a situation you want to be in if you're on a road trip somewhere or in the middle of rush hour.
