07-31-2023, 10:09 PM | #1 |
Rep 74
Drives: BMW M240i
M2 wheels on the M240I
Can we fit the stock wheels on the new M2 on the our car? Or would the offset and the size cause rubbing issues?
08-03-2023, 10:42 AM | #2 |
Rep 129
Drives: 2017 M2 Mineral Gray
Subscribed…wondering the same thing about what will fit on my M240i
08-08-2023, 07:21 PM | #3 |
Rep 87
The G series M2, M3 and M4 offset for the rears is too low for G42, so being 10.5” wide they poke out a lot and will definitely rub. But, you can run a square set of all fronts 9.5”, with a 255/40 front - 265/35 rear tires. Rears will be really flush as the offset difference would be like running a 20mm spacer.
08-10-2023, 01:37 AM | #4 | |
Rep 74
Drives: BMW M240i
08-10-2023, 11:39 AM | #5 | |
Rep 87
You could run 255/40 square, (just not with a runflat tire) but it's possible you could still have rubbing issues at the rear if lowered. |
08-11-2023, 04:13 PM | #6 | |
Rep 112
I would love to try and run a square setup with the 9.5 Fronts of these 930M's or the M3/M4 826M's. |
G42.Drxw57.00 |
07-28-2024, 09:45 AM | #7 | |
Rep 24
Thinking of running 826M wheels |
AdonisP91112.50 |
07-28-2024, 10:23 PM | #8 | |
Rep 75
At +25 offset you'll definitely be OK. Lower offset that that is uncharted territory. |
10-20-2024, 12:58 PM | #9 | |
Rep 75
AdonisP91112.50 |
01-16-2025, 12:26 AM | #10 |
Rep 93
01-16-2025, 12:27 AM | #11 | |
Rep 93
01-16-2025, 04:30 PM | #15 |
Rep 93
That’s really helpful, thanks. I saw from one of your threads you only ran them for a few months, did you run into any issues that made you change your mind? I like the wheels but am a little worried about the et20 fitment on the rears. You seem to be one of the only one’s who has actually tried this, so your feedback is really appreciated.
