07-31-2023, 10:33 PM | #1 |
Retired Major
1062
Rep 764
Faraday Pouch
Any thoughts on subject item to protect the passive signal from the fobs?
https://www.amazon.ca/Faraday-GICENT...zcF9hdGY&psc=1
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
08-01-2023, 01:30 PM | #2 |
Rep 161
I have one.
Seems to work well enough. If the keys are in the pouch I can't open the drivers door. |
Albator_IIII1062.00 |
08-01-2023, 08:59 PM | #3 | |
Retired Major
1062
Rep 764
From this site: https://www.bimmer-tech.net/blog/ite...ut-bmw-key-fob "CAN MY BMW KEY BE HACKED? As it's responsible for protecting your vehicle, your BMW's remote key fob was designed with security in mind. A sophisticated system means that your vehicle will only unlock when receiving a unique identifying signal from your fob, and the expected signal constantly changes. This makes it all but impossible for a third-party to hack your vehicle or clone your key. In fact, most criminals won't even try to hack your key or break the security system. The more common threat is a third-party getting within range of your key fob, for example by sitting at the next table. In this case, it's possible to use a signal amplifier to broadcast the identifying signal from your key to an accomplice at your vehicle, who can then use the signal to access your BMW. In these situations, some people prefer to keep their fob in signal-blocking pouch, which means a key fob power amplifier will not be able to detect your fob. The standard BMW key case does not include this feature, and is made only to protect your fob from scratches. However, if you lose a key and worry that it will fall into wrong hands you can use the service of a key fob deactivation, which will block the key fob in the memory of the car to make it useless. Key fob deactivation can be done either by the dealer or our technicians."
08-02-2023, 07:26 AM | #4 | |
Retired Major
1062
Rep 764
With the economy in its current heading and crime being on the rise, I just wanted to bring us together to consider all angles. I am on the fence on getting a Faraday pouch. They seem cheap but I am simply not convinced it is warranted for my lifestyle but wanted other points of view on this.
deleted_807865_k0a0df9ee6877.50 |
08-02-2023, 12:53 PM | #5 | |
Rep 1,512
Drives: G87, G26, E46, Mk6 5K
08-02-2023, 01:08 PM | #6 | |
Rep 1,512
deleted_807865_k0a0df9ee6877.50 Albator_IIII1062.00 |
08-09-2023, 02:44 AM | #7 | |
Rep 122
I made two suggestions to BMW about CA. Firstly, it should be able to be deactivated in iDrive so those that don't want it can switch it off. Secondly, all cars, whether they have CA fitted or not should have the same door handles. The different door handles fitted to CA cars is an open invitation for someone to target them for a relay theft. If a CA fitted car could not be distinguished in this way it would make life so much more difficult for potential thieves. Needless to say BMW has taken no notice of either suggestion.
G42 M240i xDrive. Brooklyn Grey, 19" Bicolour Double-spoke style 893 M alloy wheels with performance tyres, Technology Plus Pack, M Adaptive Suspension, Harman/Kardon Surround Sound Audio System, Heated Steering Wheel, Aluminium Rhombicle Interior Trim
