08-07-2023, 01:17 AM | #1 |
Rep 15
possible rod knock 2013 n55
Hey everyone,
I’m not sure if this is rod knock. The transmission is in park during the first video, there is a loud ticking/knocking. The second video has a spudder sound. The third video I disconnected the transmission from the engine. It’s a lot harder to hear any odd noise. When doing all this I also replaced the oil pan gasket & inspected the transmission pump. I didn’t find any of the bottom rod bearings to have play. I did replace the flex plate and torque converter but still had the same sounds. Thanks for any help! Bell housing knock https://youtube.com/shorts/2P0ka9FVjQQ?feature=share Acceleration noise https://youtube.com/shorts/2ZTuICnkG-w?feature=share Engine running with transmission disconnected https://youtube.com/shorts/Ss56cGv1In8?feature=share |
08-07-2023, 03:16 PM | #3 |
Rep 666
You can check your rod by opening up the spark plug port and use a long enough 3/8" extension to pass through the port and press against the pistons.
This is a quick one to learn from: https://youtube.com/shorts/5y4Iy5aU6DA?feature=share
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
08-12-2023, 02:01 PM | #6 | |
Rep 10,373
Just peak at your oil filter and housing. Look for glitter.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
08-13-2023, 06:12 AM | #7 |
Rep 383
08-13-2023, 06:57 AM | #8 |
Rep 10,373
08-13-2023, 09:40 AM | #9 |
Rep 383
Ah yes, you have convinced me with your eloquent rebuttal….
Care to actually explain what you are thinking, or post some form of source material? I can’t imagine an oil analysis being less specific than looking for shinies in the oil filter. And form personal experience a spun bearing will shoot up the copper ppm beyond the normal 2-3ish. |
08-13-2023, 05:30 PM | #10 | |
Rep 10,373
Basically a false negative is possible.
08-14-2023, 02:09 PM | #11 | ||
Rep 383
Hardly supports the statement: Quote:
But I know I can find plenty of examples of oil analysis which did confirm a problem, my own included. |
08-14-2023, 04:34 PM | #12 | |
Rep 10,373
https://bobistheoilguy.com/forums/th...g-wear.107183/ It's kinda of silly for the OP to pull a sample for a single-pass UOA without commenting on whether there's glitter in the filter.
08-30-2023, 07:17 AM | #15 |
Rep 34
I have a similar noise, but only with warm engine and a lot less loud than yours.
I replaced the flex plate, torque converter, rod bearings (the old ones have been fine). All pulleys, belts and so on. No change unfortunately. Oil reports show no irregularities. |
08-30-2023, 07:00 PM | #16 |
Rep 15
When my car is in drive on the lift the knocking turns to a intermintant rattling. I’m starting to think that it’s worn transmission bushings
Output shaft play https://youtube.com/shorts/k-6LRbjP3...9X9p1HJaTP1vuH Transmission rattle https://youtube.com/shorts/17SMv6wJM...XYqlbhS6FSuzxU |
08-31-2023, 09:41 AM | #17 |
Rep 666
I can't help but agree with your suspicion. Is there a way the transmission can be diagnosed by a transmission shop quite easily without having to remove the tranny? I remember in your first post that you did have your transmission off the car and engine running. On that video, I find much less irregular rattling. With the latest videos, I hear more of a muffled irregular rattle. Anyway, very interested to know what's the final diagnosis, but if there's no more reason to suspect motor being the culprit, I'm in for more learning about the transmission if that turns out to be it.
08-31-2023, 10:52 AM | #18 |
Rep 15
the bell housing knock is when it’s in park. last video is when the transmission is in neutral. I ordered the rebuild manual off of eBay. Taking off the transfer case really is the only way but at that point you might as well drop the transmission. Took me 4 hours to drop trans
09-01-2023, 02:12 PM | #19 |
Rep 666
Eager to find out the outcome, hopefully that noise can be fully addressed after the transmission replacement.
09-14-2023, 09:16 AM | #21 |
Rep 666
DM'd.
09-14-2023, 10:39 AM | #22 |
Rep 666
By the way, did you get that possible transmission issued fully worked out? or are you in process of rebuilding it, seeing how you've obtained a full set of service manual.
