BMW M2 Forums 2023+ (G87) iDrive, Nav, Stereo, Bluetooth, Electronics
      08-09-2023, 07:11 PM   #1
jason1337
Drives: G42 M240i
Google Assistant
Does anyone know how to add Google Assistant to the long press function of the microphone button? I saw it in the list before doing a factory reset (to delete the previous owner's primary user) and now it's gone, only Alexa is there. I am using Android Auto and the Assistant works when tapping the microphone button on the screen.
On another note, is there a Discord? I realised that there isn't a lot of info online regarding some of the functions on the car and/or iDrive 8 just because it's relatively new, so I now have a bunch of questions that I could ask all at once if there was a corresponding server.
      08-09-2023, 08:41 PM   #2
Squidget
Drives: 2023 G87, 2011 E90 335i
After you've paired a car with an Android device, the option to use long-press appears in the ID8 settings.
I don't remember any more details than that, but it wasn't anything hidden.
      08-09-2023, 09:02 PM   #3
Squidget
Yep.
Voice Control -> Long Press -> Google Assistant
The option should be there as long as you have successfully paired your phone. Does Google Nav work, for example?
Edit: I don't know of any Discord server for id8.
      08-09-2023, 09:06 PM   #4
jason1337
Drives: G42 M240i
Originally Posted by Squidget View Post
Yep.
I'll try to unpair and pair again then, but yeah everything else works as it should, just not this for some reason.
Squidget3813.00
      08-10-2023, 07:21 PM   #5
jason1337
Drives: G42 M240i
So that didn't work... I tried removing the phone and adding it multiple times, there's even a tick box when pairing that says "long press microphone button" but it doesn't change the fact that I can't select Google Assistant in the list of additional speech assistants. Interestingly when I pressed the mic button and asked the BMW assistant "set up Google Assistant" it replied with: "Google Assistant is not available in this country." Where can I check what country it means? My BMW account is set up for UK.
PS: I have an M240i and posted in the wrong forum, maybe I should wander over to the G42 section and ask the same question?
      08-10-2023, 09:22 PM   #6
Squidget
OH! I didn't even notice your country. Well, then I don't have a clue, maybe there's some daft law on the books in the UK? Sounds like a question for your CA.
Sure try over in the G42 forum, sorry I couldn't be more help.
