08-11-2023, 03:34 PM | #1 |
Rep 13
CS/CSL Software conversion
Has anyone tried this on the new g87 platform? Seems to be quite successful on the g80/82 platform. Best part is, its BMW software, so shouldnt affect warranty?
CS/CSL Software Conversion - Done remotely from UK to USA CS Transmission - Faster, smoother shifts. Higher clutch clamping and better rev matching on down shifts. Stops the kangarooing. The perfect blend between the older dct’s very aggressive nature and the too soft original ZF software. CS Power Steering - Sharper, loads up faster and improved feedback for better control and handling. CSL Traction Control - Improved handling and more slip in MDM Mode before the power is cut. CSL Differential - Better launch, more traction and improved handling. Works in conjunction with traction control and manages power transfer through the wheels better. CSL Suspension - Better turn in and more planted on when exiting corners, stiffer in sport plus, refined and impovement on handling in general. This is done by taking the OEM CS software and putting it on the stock car, they use the same hardware so works flawless. Engine ecu is not touched. To do it remotely you'll need a BMW enet cable and have use of a windows laptop with ethernet port or USB to ethernet adapter. |
08-11-2023, 03:37 PM | #2 |
Rep 389
it affects warranty... software is not supposed for g87.. so warranty is gone
dead.pixel103.00 |
08-12-2023, 07:19 PM | #3 | |
Rep 130
08-13-2023, 05:05 AM | #4 | |
Rep 1,052
08-14-2023, 04:48 AM | #5 |
Rep 520
We have done this on our G81 M3, and it's very good. Plan to do it on our G87 M2 also.
Any software changes most likely will void your warranty, regardless of whether its BMW software or not.
dead.pixel103.00 Bumpinjeep5532.50 |
08-14-2023, 06:51 AM | #6 | |
Rep 3,057
CS is for AWD cars only. We offer it worldwide - check the signature.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-14-2023, 07:33 AM | #7 | |
Rep 1,052
Is it possible to request the CSL transmission software on an XDrive car? Last edited by somer; 08-14-2023 at 07:38 AM.. |
08-14-2023, 08:58 AM | #8 |
Rep 2,987
Drives: A Family Sedan
aerobod3625.50 dead.pixel103.00 |
08-15-2023, 10:17 AM | #10 |
Rep 3,057
Thank you You can check reviews either at website or trustpilot (you can't modify them just FYI)
All OEM BMW software, so it doesn't get flagged by ISTA.
08-15-2023, 10:40 AM | #11 |
Car Geek
3626
Rep 3,594
Assuming you have a licence agreement with BMW to redistribute and modify their software configuration? If so please post a link to it. Otherwise this is just unauthorized modification which will void the warranty (as typically specified in BMW and any other car manufacturers warranty terms and conditions). Installed versions and configs will differ from factory shipped versions, which BMW can easily check if there is a problem that involves their investigation.
08-17-2023, 08:37 AM | #12 |
Rep 6
Drives: F10 530d 2011 245/540
All cars post 2022 are ECU locked, does it need to be unlocked to install this software? Or is to a smooth install?
08-17-2023, 11:39 AM | #13 |
Rep 3,057
DME is only locked for tuning, you can do anything with those cars via E-Sys
08-17-2023, 11:54 AM | #14 | |
Rep 2,987
Similar to engine tuning, nothing may be "flagged", but if the engine breaks, they will analyze the parameters and if they see that boost was higher, for example, they will deny warranty. I think it's a similar principle. |
08-17-2023, 01:29 PM | #15 | |
Rep 3,057
dead.pixel103.00 M Division1197.50 |
08-17-2023, 02:13 PM | #16 |
Rep 2,987
Are you saying the ECU stores a flag if you install a Juice Box piggy back? My understanding is that it is completely invisible, and if you remove it, no one "knows".
08-17-2023, 02:19 PM | #17 |
Rep 3,057
your box is not a proper engine tune, and don't be fooled by anyone saying it won't know, logs will tell the truth.
dead.pixel103.00 |
08-17-2023, 02:38 PM | #19 |
Rep 6
08-17-2023, 04:00 PM | #20 |
Rep 1,477
Drives: BMW M2
I wonder if the CSL differential calibration works well with street tires or if it is tuned on the extra grip of the Cup 2R.
08-17-2023, 10:23 PM | #21 |
Rep 2,987
08-18-2023, 03:05 AM | #22 |
Rep 3,057
i will not argue with you, but you're using some piggy back and afraid of doing transmission flash with oem software
deucedude10.50 |
