Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Maxton Design Rear Valance Install
      08-20-2023, 02:47 PM   #1
g20_wumbo
g20_wumbo's Avatar
Drives: 2019 BMW 330i
2019 BMW 330i  [0.00]
Finally received my Maxton design rear valance and I’m happy with the way it looks. Was running an eBay m performance replica diffuser before. Wasn’t too crazy with it as it wasn’t aggressive enough for me.
Only caveat with this diffuser is that the tabs for the diffuser don’t snap into place on the car. They really just slide into place and sit there. Other than that, it’s great.
Side skirts are next
      08-21-2023, 12:01 PM   #2
Two3Series858
Two3Series858's Avatar
Drives: 328i, 330i
2015 BMW 328i  [0.00]
Looks great man! I have the non-M Maxton rear diffuser and its held up well. The 3M tape is key, but so are the numerous screws to keep it in place.
The only thing that sucked about the Maxton skirts was losing the Welcome Light (turned the feature off). Unless you can modify them to allow the light to shine down through. The 3/4 M -Sport ones won't give that issue, but the full-length Maxtons look better and match the contour lines over the car IMO.
      08-23-2023, 06:34 PM   #3
g20_wumbo
g20_wumbo's Avatar
Yeah, that's what I was afraid of when deciding between the Maxton and the 3/4 m sport ones. Ended up buying the m sport skirts to avoid that issue.
      03-24-2024, 02:52 AM   #4
BMWG20_330i
Drives: G20 330i
How did you manage to secure both sides? Since the tabs do not snap into place..
      03-27-2024, 08:02 PM   #5
g20_wumbo
g20_wumbo's Avatar
I just left it alone. It doesn’t slide out too much. 1/4 of an inch at the very most. Doesn’t bother me much. The bottom portion is secured so overall it’s not going anywhere
      04-02-2024, 11:33 AM   #6
elirdt
Drives: bmw 2021 g20 330i m-sport
[QUOTE]
Did u have to drill any new screws cause i want to get this but Im not trying to drill any new holes.
      04-02-2024, 10:35 PM   #7
g20_wumbo
g20_wumbo's Avatar
[QUOTE=elirdt;31038833]
Nope. I didn't drill any new holes. The diffuser uses the same hardware as the OEM diffuser. Very easy install.
      04-02-2024, 10:37 PM   #8
elirdt
I’ll buy it right now. Was there anything specific that you struggled with? Also did you jack the car up to install it?
      04-02-2024, 10:41 PM   #9
g20_wumbo
g20_wumbo's Avatar
There wasn't anything I really struggled with this install. It was really straight forward. Jack was not needed for the installed. Pretty much got underneath it and got to the bolts easily.
If you want, you can look up a YouTube video on how to remove the OEM diffuser. Once you watch that, you'll be able to install the Maxton one no problem
      04-02-2024, 10:43 PM   #10
elirdt
Ok thanks. By chance did you install a front splitter on your car?
      04-02-2024, 10:48 PM   #11
g20_wumbo
g20_wumbo's Avatar
Yup I did. I went with an eBay replica of the M performance splitter. Fitment was 7/10. I ended up cracking the extensions to the splitter, so I'm thinking about changing to a different one this year.
      04-02-2024, 10:49 PM   #12
elirdt
Did that require self tapping screws or also only used factory screws?
      04-02-2024, 10:51 PM   #13
g20_wumbo
g20_wumbo's Avatar
It used factory clips as well as self tapping screws.
      04-02-2024, 10:54 PM   #14
elirdt
What else do you have done to your car I basically have the same car just black rims
      04-02-2024, 10:59 PM   #15
g20_wumbo
g20_wumbo's Avatar
All I have done to the car at the moment in terms of cosmetics is splitter, diffuser, m performance replica side skirts, 30% ceramic tint, shadowline grille, JB Speed rear spoiler (type 2).
Next mods are hopefully black mirror caps, darker tint, and wheels and tires.
      04-02-2024, 11:01 PM   #16
elirdt
Did side skirts also use self tapping screws?
      04-02-2024, 11:04 PM   #17
g20_wumbo
g20_wumbo's Avatar
Yes, 3M tape as well as self tapping screws, though not many. I think I used 3 or 4 on each side.
g20
