08-20-2023, 10:49 PM | #1 |
Rep 6
B58 rebuild
Hi guys, I am planning to tune my m140i since it just got out if warranty.
I was trying to figure out all the cost that could show up in the future in case of an engine failure... while I was trying to figure out the costs I notice that some people stated that the b58 engine cannot be rehoned and sleeved. The problem is that going down the road of buying a new block sadly its not a possibility for me.... I asked my mechaning to quote me how much would be to rebuild the engine and he gave ge quite a good number (seems like a good deal) but it would be his first b58 rebuild... So I was thinking that he might threats the b58 as a normal engine not taking in consideration the LDS. Thanks for the help |
08-21-2023, 07:57 AM | #2 |
Rep 106
If your so concerned that just because you tune your car you think it’s going to blow up, maybe tuning isn’t for you. You joined and have just 3 posts and all are about rebuilding your engine. If you truly think the B58 engine is prone to blowing up just because of a tune, you should probably just not do it, you’ll sleep better at night.
08-21-2023, 11:09 AM | #3 |
Needs more boost.
93
Rep 45
Stage 1 mapping via something like BM3 is basically idiot proof. If you somehow manage to break something it most likely won't require an engine rebuild anyway.
Current- 2017 340i (F30) M Sport: EB II | M Performance LSD | M Performance Brakes | M3 Paddles | Forge Panel Filter | Hot Climate Intake
Previous- 2017 M140i (F20): AW | M Performance Exhaust |
08-21-2023, 02:10 PM | #4 | |
Rep 6
Now I am just trying to figure out some numbers about the rebuild cost. Most importantly I am trying to understand what can be done to the engine itself, more precisly if its truly possible to rehone and sleeve the cylinders, instead of buying a whole new block. Also I wanted to double check if more experienced users could guide me through by telling me if my mechaning is telling me bs about the rebuild... I really want to prevent as many headache as possible, while still being able to tune the car, starting with an MHD stage 1 and maybe later a stage 2 |
08-21-2023, 02:12 PM | #5 | |
Rep 6
I pulled the trigger on the b58 after seeing some reliability articles and also due the fact that I needed a hatch |
08-21-2023, 09:10 PM | #6 |
Rep 3,190
You are mixing things. You can't rehone the cylinder walls, you HAVE to sleeve them. But the only reason to do that is if you are trying to run 700+hp.
08-22-2023, 12:27 AM | #7 |
Rep 6
Oh ok thank you so much, now I am starting to get it. but why do some people say its not possible to sleeve the b58?
08-22-2023, 03:01 AM | #8 | |
Rep 1,449
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
08-22-2023, 06:40 AM | #9 | |
Rep 3,190
https://www.p2uned.com/product-page/b58-sleeved-block https://store.vacmotorsports.com/mobile/vac-motorsports-block-sleeving-service-bmwtoyota-b58-p5298.aspx Link to this forum from a Google search https://f30.bimmerpost.com/forums/showthread.php?t=1901521 |
08-22-2023, 07:06 AM | #10 |
Rep 106
Did you ever post what you're planning on doing to the car? If you're just going with a stage 1 or 2 OTS tune and maybe a downpipe, don't even waste your time researching rebuilding it.
Now if you're plan is 800-1000 hp build, that's another story. |
