09-05-2023, 10:42 AM | #1 |
Rep 618
G8x Comp RWD owners: do you regret not getting xDrive?
Hi guys,
I currently have an M2 Comp and was honestly planning on making an(other) impulse decision of getting a G80 but I’ve decided to slow down and give myself time to save some more money up as well as wait for interest rates to fall down before getting one. This brings me to my question: do any of you Comp RWD guys regret not going for the xDrive model? I’ve asked some friends who owned G80s and they said that the xDrive is just miles better than the RWD and never get a RWD version (he’s driven both). I know I should be the final judge by test driving but there’s only so much you can do in a test drive (go around the block near the deslership). I’ve already tested out a 23’ G80 xDrive and it felt great, especially when gunning it from a red light. I’m wondering if the RWD is really as bad as the xDrive people say and if it’s worth dishing out the extra 10k for the xDrive (used market).
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
09-05-2023, 11:34 AM | #3 |
Learning to drive again
735
Rep 333
Drives: M3CS
Cheers,
BoB |
09-05-2023, 01:33 PM | #4 |
Rep 2,167
Nope, no regrets.
But if you're buying a G8X and you need it to "hold its value" to maximize its value on a future trade, then get AWD. If you're a stoplight racer and love having the absolute lowest 0 to 60 times, then get AWD. If you like to drive aggressively and swiftly in inclement weather, get AWD. If you plan on taking your G8X out in the snow or ice, get AWD. None of this applies to me, so again, I have zero regrets. And I've driven both RWD and AWD on the track, and for me, the biggest advantage of AWD is on a track, with all the traction control nannies off. Then you realize just how early in a turn you can jump on the throttle and the AWD sorts it all out and pulls the G8X through the turn. With RWD, you have to really understand the throttle inputs on a track, though RWD with MDM on or with the 10-stage traction control is pretty damn good too, but it's still going to squirm a bit. AWD squirms a bit too, but for like 1/2 a second... whereas the RWD is like a second. It sounds like a minute difference, but on a track, it makes all the difference....especially in regards to confidence. On the road, AWD feels more secure as well on some of the tightest turns. You can just jump on the throttle early. Otherwise, the RWD is fine, but you need to keep the TC on (and only graduate to MDM mode when one is comfortable). The good news is that the TC is not obtrusive, unless you're trying to fly through a hairpin turn (then it will simply cut all power so you don't go into a full power slide). So, for me, if I found an RWD and AWD that I wanted within about $5k of each other, I'd get the AWD. $10k difference, I'm getting the RWD. Last edited by KevinGS; 09-05-2023 at 07:26 PM.. |
wowwitsgau180.50 jmase248301.50 |
09-05-2023, 02:26 PM | #6 |
Rep 781
I regret not getting the FWD CVT edition with the front bench seat option.
09-05-2023, 02:47 PM | #7 |
2020 Z4 M40i - 2022 M4C Convt
3131
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Honest statement, I have AWD in my M4 & have no regrets. Am not in debate mode pushing AWD vs RWD. I also have a powerful RWD car that greatly exceeds the cars traction capability but its not a BMW.
Since these cars came out I have always wondered how does the AWD's RWD capability stand up against a real RWD version. No G8XX cars were available to drive when I ordered mine. Since the AWD car can also run as a RWD car has anyone with strong RWD preference ever made a comparison as how the AWD car stands up as a RWD car?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
gnx759.50 |
09-05-2023, 03:00 PM | #8 | |
Rep 2,687
Drives: 2024 M4 Convertible
BEAR-AvHistory3130.50 |
09-05-2023, 04:02 PM | #9 |
Rep 14,135
Drives: G82 M4C X-Drive
After 2 RWD M3s I opted to try out the M X-Drive for my G82 with only a 99 lbs penalty. No regrets. To reiterate other's experience, the most gain is in the 0-60 drag an on the track. Since I attend regular track days the X-Drive has been great for me. However, I know that the RWD is still super grippy and you save a bit of weight. I don't think you will regret going either way.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-05-2023, 04:07 PM | #10 | |
Rep 14,135
The X-Drive penalty is 99lbs, not 200lbs, but it's still not an unnoticeable amount at the very limit. The added benefit of being able to throttle out a bit sooner still nets a faster time in general, and it takes a small amount of driving style change to take advantage of it. Luckily there is still butt-gyro communication despite the lack of steering feel, so it's fairly easy to gauge. The only other limitation is tire choices. You have to be within 1% rolling diameter, which limits your tires choices vs RWD, which has no such limitation.
BEAR-AvHistory3130.50 PVC162.00 |
09-05-2023, 04:39 PM | #11 |
Rep 6,771
09-05-2023, 04:48 PM | #12 |
Rep 995
Drives: 2024 M4 Comp X-Drive
The manual version makes it pure
2024 Dravit Grey M4 Competition X-Drive
09-05-2023, 05:13 PM | #13 |
Rep 865
Drives: 2021 BSM G80 comp
How many times will this be asked lol
2021 G80 Comp
09-05-2023, 05:30 PM | #14 |
Rep 1,612
Not sure what experience you have but I don't like AWD and never have. If you think you need it, go for it.
BimmerFix1405.50 LuckyBrand1414.50 |
09-05-2023, 06:20 PM | #15 | |
Rep 6,771
Have owned all manner of FWD, AWD and RWD. Torque converter, Dual Clutch autos. Naturally aspirated, Turbo, turbo diesel, hybrid and full EV. 4, 5, 6 and 8 cylinder engines. I completely respect your right to your choice. Nothing wrong with RWD whatsoever. I’m not asking you to like the AWD. But to call a G80 a “pure” driving experience, even in RWD, Manual form when the car has a twin turbo direct injected engine, computer controlled trans and diff, with EPS, multi stage traction and stability control, three way electronic shocks, abs, brake by wire, and enough modes to make a computer programmer dizzy. Not to mention digital gauges, climate control, HUD, LED ambient lighting, iDrive, heated seats, and on and on and on PURE. Well, it’s not really very pure. Lot of electrons between you and the road. It's not even pure compared to cars sold today, like the BRZ, Miata, Z, etc. Sorry if my initial post was harsh. But some frame of reference is often helpful. Especially if you’ve ever driven a car with a 2 barrel carb and no ABS or power steering. Jesus I really have turned into the old guy. Get off my lawn. Lol. Last edited by Needsdecaf; 09-05-2023 at 06:26 PM.. |
PipeM3200.50 |
09-05-2023, 07:21 PM | #16 |
Rep 42
09-05-2023, 07:30 PM | #17 | |
Rep 14,135
On the track, my G82 X-Drive can still throttle steer, only it recovers faster and pulls you out of the slide with more control so you can get harder on the throttle sooner than my RWD M3 and M3 CS did. Trail brake, rotate, transition to throttle, adjust the rear with the throttle, then power out sooner as you corner exit. You don't feel this on the street, unless you are driving like a maniac and should have your license taken away. At street speeds, what you will feel is harder acceleration, and less oversteer if you accelerate too fast then turn the wheel. Also, my F80 M3 CS would fishtale easily if it's cold or wet with track rubber. With X-Drive it's a little more stable.
kjx3212.50 |
09-05-2023, 08:39 PM | #18 |
3131
Rep 5,264
Nah, its a great car but its not "pure". Throttle house said it is fast, comfortable, civilized, livable, all the technology you could ever want. Does not read very pure.
I would think benchmark pure is manual steering, manual brakes, manual transmission & no computers. Like the car Throttle House tested & recorded below. They even used the P word. Described by the Throttle House guys as a "Homicidal Maniac". A loud, dangerous and unruly machine of PURE driver engagement. It also weighs only 2250 pounds with 520 horsepower that explodes out the side-exit exhausts and straight into your eardrums. https://youtu.be/81OVZnHWd2A
Kevin
jmg18834.50 |
09-05-2023, 09:22 PM | #19 |
Rep 388
No regrets at all.
Will soon order my next G8X and it will be another RWD Comp. Certainly not going to try and justify one versus the other and highly doubt you will be disappointed no matter which you get.
TJR
09-05-2023, 10:35 PM | #21 | |
///M ♥ Recycled Dinosaurs
3213
Rep 1,781
Drives: BMW M4, BMW X5 45e
People who want 'pure' driving experiences shouldn't be driving a car with traction or stability control or an automatic transmission. And they certainly shouldn't be doing it in a class of car as heavy or luxuriously cosetted as the G8X. And yet, these wannabe purists show up to talk down one of the biggest value props of the G8X generation - the AWD. It's probably one of the only options on the car that appreciates 2x-3x it's MSRP delta in the used car market (4k new translates to 8 to 12K bump in the used car market). And there's a reason for that - supply and demand - less people sell their AWD cars and more used buyers want it. Of course, people holding an RWD dead duck would want to talk it up to deal with their own cognitive dissonance and/or until it becomes someone else's problem.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
09-05-2023, 10:38 PM | #22 |
Rep 14,135
I get the feeling those who think the RWD is more "pure" haven't driven the X-Drive. It's rear biased. It's got all the character of a RWD car with the advantages of a AWD car. It's just cost, 99lbs, and packaging. Neither is "pure".
