BMW M2 Forums 2023+ (G87) Exterior Modifications
      09-23-2023, 08:30 PM   #1
Landiah
Landiah's Avatar
10
Drives: g87 m2
Carbon grill
Has anyone tried any of the carbon grilles off ebay or know of any other alternatives other than the Alpha N ones?
      09-24-2023, 05:33 PM   #2
rcouchh
rcouchh's Avatar
Drives: BSM G87
Tempted to try... they're $650 vs the Alpha-N is $1500
      09-25-2023, 01:10 AM   #3
Landiah
Landiah's Avatar
10
Drives: g87 m2
https://a.aliexpress.com/_mtQ4Va2
This one here is $400 I’m thinking about pulling the trigger.
      09-25-2023, 07:46 PM   #4
Chicanery
Driver
Chicanery's Avatar
79
Drives: United States
2023 G87  [0.00]
Please report back if you pull the trigger on these.
      09-26-2023, 10:57 AM   #5
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.00]
I would think these are cheap plastic parts with a carbon sticker or some really messed up weave. Why not simply take your current grill and hydro-dip it in "carbon?" I would think that would achieve the same look at a much lower price and at least you know it's going to fit properly since it's a true BMW part.
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed
      09-26-2023, 02:07 PM   #6
rcouchh
rcouchh's Avatar
Drives: BSM G87
Maybe you don't realize what carbon fiber is, but even OEM BMW carbon parts are just a cheap fiberglass or plastic component with a piece of carbon weave laid on top and clear coated.
Unless you're talking about a roof or pieces like the CS carbon hood, everything is like that. Even more reason to buy cheaper alternatives.
      09-26-2023, 04:24 PM   #7
M_Power Rob
Drives: '23 M240 and '23 M2
Yes, you are cirrect but there are definitely different grades and quality levels.
      09-26-2023, 05:34 PM   #8
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.00]
Incorrect. OP was referring to Alpha N vs eBay/Alibaba knock off, which is exactly that, plastic with a weave sticker on it. The Alpha N part is carbon through and through. That's why one is $1500 and the other is a third (but really should be more like a fifth) of that.
      09-28-2023, 07:03 AM   #9
Chris13002
Drives: 2023 BMW M2
I personally would never paint, hydro-dip, or even wrap a front grill. Rock chips will eat through it much quicker and it will look worse than what you started off with. I also don't like the fact that you lose the M2 emblem in the front.
Bumpinjeep5532.50
rcouchh2360.00
DBV778.50
      09-29-2023, 05:06 PM   #10
Spoolin Montego
Spoolin Montego's Avatar
604
Drives: 16 m3/20 x5m/23 m3
Simply untrue. Name ONE OEM cf part that is fiberglass base...I'll wait.
There is like 10 different ways to make a CF item all with varying degrees of quality. OEM items are always full CF with no fiberglass.If they used fiberglass you would see black on the back rather than CF weave.
aerobod3625.50
      09-30-2023, 06:10 AM   #11
DBV
DBV's Avatar
779
Drives: G87 M2, G20 330d, Brabus Smart
2023 BMW M2  [8.75]
2018 Brabus Smart  [0.00]
2021 BMW 330d  [0.00]
I had IND make a "shadow chrome" version of the F80 grille when I had my M3, and it looked amazing until I got the first rock chip. In hindsight, PPF is a must on any front end pieces.
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart
Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp)
