      09-24-2023, 04:05 AM   #1
Craw2theJ
Craw2theJ's Avatar
Drives: BMW 750i
Battery Terminals under hood
I'm trying to install the ctek battery charger eyelet cords and was wondering when removing the terminals under the hood do I need to remove them in a certain order or do I need to disconnect the battery before doing so? I'm hoping not to have to disconnect battery and just unscrew the negative post first then the positive post and connect in reverse order.
Thanks in advance for any help!
      09-24-2023, 04:19 AM   #2
spammysammich
spammysammich's Avatar
2009 BMW M3  [10.00]
why would the order matter? Aren't they an open lead until you plug them into the ctek?
      09-24-2023, 05:03 AM   #3
///M Power-Belgium
///M Power-Belgium's Avatar
Belgium
73481
Drives: ///M3-E92-DCT Silverstone II
This way , It's much easier
"MAX VERSTAPPEN" IS THE 2021+2022+2023+2024 F1 WORLD CHAMPION - #UnLeashTheLion -
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod.
DrFerry7427.50
M5Rick72339.50
      09-24-2023, 08:07 AM   #4
Craw2theJ
Craw2theJ's Avatar
Drives: BMW 750i
I don't know if the order matters but I figured disconnecting/connecting the same order as you would the battery couldn't hurt.
      09-24-2023, 08:18 AM   #5
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Thought it isn’t wise to connect a tender directly to the battery?
2023 G42 ///M 240i xDrive Thundernight Metallic
      09-24-2023, 08:21 AM   #6
Craw2theJ
Craw2theJ's Avatar
Drives: BMW 750i
Those photos don't seem to be connecting to the terminals under the hood like the original question was intended. I've read multiple places not to hook straight to the battery and my owners manual states specifically to charge and/or jump from the terminals under the hood. Connecting directly to the battery bypasses the ibs and can potentially cause issues.
      09-24-2023, 08:27 AM   #7
HighlandPete
Drives: BMW F11 535i Touring
Looking at your image, you are not connected correctly. (??) You do not have the IBS in the charging circuit.
Front connections, we are charging as intended, keeping the energy management in the loop, allows for correct charging in use.
      09-24-2023, 08:30 AM   #8
cbpip
cbpip's Avatar
270
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
You don't need to remove either cable. Just the nut, place eye ring connector on post and reinstall the nut.
      09-24-2023, 08:38 AM   #9
Tobstertx3
Drives: 2024 BMW M3
Interested for future responses.
In my previous vehicles I’ve always hooked it up directly to the Battery and still doing it to this day without any issues.
      09-24-2023, 08:46 AM   #10
///M Power-Belgium
Belgium
73481
I've got zero issues in the last 10 years .
DrFerry7427.50
M5Rick72339.50
      09-24-2023, 08:51 AM   #11
Tobstertx3
Drives: 2024 BMW M3
Some more info
https://g80.bimmerpost.com/forums/sh....php?t=1927609
      09-24-2023, 08:58 AM   #12
Tobstertx3
Drives: 2024 BMW M3
You leave this connected to the battery at all times and just switch on the charger when needed?
      09-24-2023, 09:09 AM   #13
///M Power-Belgium
Belgium
73481
The connector cable-kit came with my CTEK to connect it directly to the battery with 2 O-rings for the + and - poles of the battery .
Within 5 sec. and one connector click , my CTEK is ready to charge ..
My CTEK connector kit is permanently connected to my battery .Got 'Zero issues like this in the last 10 years , CTEK is the smart battery tender
DrFerry7427.50
M5Rick72339.50
      09-24-2023, 09:20 AM   #14
///M Power-Belgium
Belgium
73481
Yes , I leave my CTEK connector connected to my battery at all times (permanently)! in the trunk.
That's how I charge my battery in the last 10 years .
It couldn't be easier
DrFerry7427.50
M5Rick72339.50
      09-24-2023, 09:31 AM   #15
///M Power-Belgium
Belgium
73481
Think , you don't need the IBS . Because CTEK is the smart battery tender .
The cable connector kit came with my CTEK battery tender to use it.
I'm pretty sure CTEK knows it better than us .
DrFerry7427.50
M5Rick72339.50
      09-24-2023, 09:37 AM   #16
HighlandPete
You may not need the IBS to charge the battery. But that leaves the energy management not knowing the current SoC. In circuit, it does.
Charging and trickle charging of the battery
...If the battery is charged when fitted, the charging process must take place via the jump start terminal point. This is the only way to ensure that the charging process is detected correctly by the vehicle electronics on vehicles with an intelligent battery sensor (IBS). If the battery is charged directly at the battery terminals, misinterpretations of the battery condition and, under certain circumstances, unwanted Check Control messages or fault code memory entries can occur. The cigarette lighter is supplied with voltage by the front power distribution box via switched terminal 30B. After terminal 30B off, the relay de-energizes. This means that a trickle charger connected at the cigarette lighter would be disconnected from the battery. Only charge the battery via the jump start terminal point.
Almuliman560.50
      09-24-2023, 11:26 AM   #17
Tambohamilton
Drives: E91 330d
This. By not having the IBS in the charging circuit, you may as well not have it all. If the IBS doesn't 'see' the charge from the ctek, it'll assume the battery is still in whatever state it was before you charged it and try and cram some more in when you next run the car.
To be clear, you don't *have* to connect to the charging posts under the bonnet/hood, but it's a simple way to be sure that the IBS is in the charging circuit.
In response to the original question, it shouldn't matter at all which you disconnect first, and you shouldn't need to disconnect the battery beforehand - just make sure any loose positive wires can't short out on the body/block/etc.
      09-24-2023, 12:46 PM   #18
Pheonix
Drives: 2007 Z4 M Coupe 2012 e93 M3
2007 BMW/Z4MC  [0.00]
I ran the cable out to under the hood/windshield and don't have to pop the hood/trunk to connect the Charger.
      09-24-2023, 12:51 PM   #19
Tejas1836
Tejas1836's Avatar
1217
Drives: 2023 X5MC Workmaster 75
NOCO Genius 10- Not a hybrid
Two is One and One is None
      09-24-2023, 12:56 PM   #20
Tejas1836
Tejas1836's Avatar
1217
NOCO
      09-24-2023, 01:02 PM   #21
Tejas1836
Tejas1836's Avatar
1217
NOCO- Not a hybrid
      09-24-2023, 04:30 PM   #22
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
FYI: Info from BMW (as others mentioned above) to not hook up directly to the battery if your BMW has an IBS (intelligent battery sensor)…because there are multiple components that communicate with each other in regard to the vehicle’s charging system.
But everyone has the right to do with their vehicle as they wish…but to those that didn’t know…BMW does not recommend bypassing the IBS.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
