BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      09-28-2023, 06:35 PM   #1
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Five blinker flashes on one touch
Anyone manage to code this?
I used BimmerCode (3 Series) and checked the option, but it didn’t take after coding.
2023 G42 ///M 240i xDrive Thundernight Metallic
      09-29-2023, 02:51 AM   #2
Pentland
Drives: BMW M240i (G42)
I’m not convinced the new models take any coding from BimmerCode these days. Try the old 2 series option.
      09-29-2023, 10:45 AM   #3
speed817
speed817's Avatar
183
Drives: G42 M240i
Have you been able to code anything successfully? I'm interested in coding the B&W audio settings and removing the warning on startup.
      09-29-2023, 02:32 PM   #4
Prince Thundernight
Originally Posted by speed817 View Post
Have you been able to code anything successfully? I'm interested in coding the B&O audio settings and removing the warning on startup.
Coded starting up in Sport Individual is about all
      09-29-2023, 03:20 PM   #5
nype
nype's Avatar
Drives: BMW M240i / BMW X5 35d
Fluid might be low?
      10-02-2023, 05:57 PM   #6
Littlecoupe
Drives: 2023 M240i
I can't comment on the 5 flashes from the OP, but I successfully coded B&W sound settings and removing warning on startup on my 2023 iDrive 8. Using an old BT dongle, no less. Used the 3 Series section of BimmerCode.
      10-03-2023, 06:42 PM   #7
speed817
speed817's Avatar
183
Drives: G42 M240i
Cool. Just coded B&W settings, removed warning on startup, adding blue magenta ambient light to match my TNM and added startup in sport individual mode. Now I just need to figure out if I can code out auto low beams for good.
      10-03-2023, 07:06 PM   #8
nype
nype's Avatar
What's auto low beams?
      10-03-2023, 07:13 PM   #9
speed817
speed817's Avatar
183
Drives: G42 M240i
The Auto button when on will automatically turn the low beams on when low light is detected. You can simply turn off the low beams when you're in the car but there's no way to turn off the auto function completely.
For example, I was driving the other day in the late afternoon with plenty of light outside but when got stuck in traffic under and overpass, the low beams came on. I don't want that. I can simply turn them off when it happens, but when I startup the car the next time, the auto function will still be there. I want to be in total control of turning my lights on and off.
nype165.00
      10-03-2023, 10:39 PM   #10
J-RO
Drives: 2024 M240ix BMW X1 28i
I coded the five blinks. You must go into the menu on idrive after you code it to complete the process.
      10-03-2023, 10:41 PM   #11
KevinC
your average JAMF
KevinC's Avatar
Drives: '21 M2 Comp, '19 Golf R
Just curious why anyone would want 5-blink lane changes? My granny in her ‘72 Buick makes faster lane changes.
      10-04-2023, 12:34 AM   #12
Prince Thundernight
How? I tried to code other colors as ‘amber’ or something. Didn’t work.
      10-04-2023, 12:36 AM   #13
Prince Thundernight
Sure it takes less time to make the lane change, but it’s the BEFORE you start the change that you want them to come on, to warn other mototists that you’re about to change lanes.
      10-04-2023, 06:26 AM   #14
speed817
speed817's Avatar
183
Drives: G42 M240i
I just made the change under “Body Domain Controller” BDC_BODY3 control unit under the 3 series options. I don't remember seeing an amber option.
      10-04-2023, 10:46 AM   #15
Prince Thundernight
Seems the coding I did the other day DID take. Five flashes on one touch, and purple ambient lights. 😎
speed817183.00
      10-04-2023, 12:58 PM   #16
Littlecoupe
Drives: 2023 M240i
That type of courteous indicating has no place in this brand. How dare you hold us to a higher standard.
      10-04-2023, 01:52 PM   #17
Prince Thundernight
Actually nothing to do with courtesy—just making sure all the other morons on the road notice me!
      10-05-2023, 12:36 AM   #18
tahoeacr
Drives: 23 M240IX
My wife wants the purple lighting. Since you got it to work I want to get the same OBD adapter. Which one you have?
Thanks
      10-05-2023, 08:27 AM   #19
mburg
MBurg
mburg's Avatar
65
Drives: '22 230
I applaud you! The notion that part of driving involves communication with other drivers - whether through the use of turn signals or through eye to eye contact (which itself has become impossible with window tinting) - has gotten lost.
      10-05-2023, 08:55 AM   #20
Prince Thundernight
Thanks
https://www.amazon.com/OBDLink-Bimme...d-1a2a0f492698
      10-05-2023, 09:39 AM   #21
Ruebarb
Ruebarb's Avatar
417
Drives: BMW G42 M240i
ID7 had the purple lighting there from the factory, is this not the case for ID8?
      10-05-2023, 09:43 AM   #22
Prince Thundernight
Nope. Nor red.
Ruebarb416.50
