      10-03-2023, 08:20 PM   #1
ipayincash
ipayincash's Avatar
Drives: F95 comp
Any experience with Jet-Hot coating ?
I have brand new Active Autowerke downpipes and was looking into ceramic coating them to help keep engine bay temps down. Does anybody have any experiences or recommendations for similar companies in LA ? I know the f95 engine bay gets super hot and that's currently in LA, I can't imagine when I take this thing to Texas in the summer. First time I ever look into anything like this and I found Jet Hot coating and they seem to be really good but it seems every place has their own "magic" recipe not sure if its all the same or what
      10-04-2023, 11:43 AM   #2
4JawChuck
Drives: 2013 128i SE
I have the Jet-Hot coating on a set of shorty headers on my sons 302 powered 98 Ranger 2wd. I also had my 128i headers ceramic coated locally as that was all that was available.
Both have similar heat rejection capabilities under the hood but the ceramic is thin compared to the JetHot.
Not an issue if you don’t need to bend/dent/modify the headers to fit, the Jet Hot coating easily accommodated denting the Ranger header to clear the steering shaft without flaking or chipping which is actually quite amazing…we expected it to come off when we pressed a 1” aluminum pipe into the header pipe to create a dent where the steering shaft would hit the pipe.
If money or availability is not an issue then Jet Hot is the way to go, it lays on like thick galvanize compared to ceramic which is like water when it’s sprayed on.
You can get ceramic coating in various Color’s too which Jet Hot cannot, take your pick…both perform similarly under the hood with Jet Hot taking the mod crown for flexibility.
      10-04-2023, 12:15 PM   #3
HondaRC51
HondaRC51's Avatar
253
Drives: 2009 E92 335xi
2016 BMW S1000RR  [10.00]
2009 335xi E92  [0.00]
DO NOT USE JET-HOT! I had Jet-Hot coat my new motorcycle headers and they turned out complete GARBAGE. It looked like they spray painted the pipes due to uneven coating and runs (how a powder coating turns into runs like wet paint is beyond me). Claimed 10-14 business days for turn around. Took 2 months to get back to me. When I called them to ask why their quality was crap, they wanted me to send the pipes back for inspection and re-coating. I would have to pay for return shipping and it would take another "10-14 business days". I tell everyone not to use them. Maybe the other location is better at coating but I don't trust them. Any powder coating shop can use a ceramic coating. Wish I went that route the first time.
      10-04-2023, 03:38 PM   #4
ipayincash
ipayincash's Avatar
Drives: F95 comp
After more digging I found a company called Swain Tech but they are in NY so would have to ship there and back.... def not going with Jet-Hot. Still looking to see if I find a well respected and recommended company based out of LA
      10-04-2023, 04:29 PM   #5
4JawChuck
I would go ceramic then, I dropped a 1/2” drive ratchet during install of the motor right onto a bend on the pipe and it did not chip.
My guy offered flat black or silver, I used flat black for my 128i header in ceramic.
The Jet Hot coating is not the most attractive for sure but our pipe coated by the mfg (Sanderson) was well done if not show quality.
The ceramic is smooth and minty looking in comparison, however you can’t even see the pipe on a 1-series anyway…who cares.
      10-05-2023, 03:11 PM   #6
Twinturbostroker
Drives: M8C & 335is
I've used Jet Hot on multiple builds.
Specifically Jet-Hot 2000.
All turbocharged applications.
Had to have one recoated after about 4.5 years.
Lead times are not the best
and their quality control did have some
variability, overall I'm still satisfied.
1 set ductile iron manifolds.
1 set stainless manifold tubes and downpipes.
Several turbine housings.
I scratched a set of downpipes when R&Ring for maintenance, and Jet-Hot recoated for free (shipping cost).
It's been several years since I've used them, but on the turbo cars that I have with Jet Hot 2000 coated manifolds and downpipes they still look and perform as advertised.
      10-11-2023, 01:56 PM   #7
Dasky_spas
Drives: Bmw
I did ceratoke 1800 on my downpipes but like the dummy I am, I didn't do before and after tests.
      10-12-2023, 01:33 AM   #8
1heckinboi
caffeine fiend
1heckinboi's Avatar
55
Swaintech is great, used them for the headers on my WRX
      10-12-2023, 03:40 AM   #9
Oldgixxer
Oldgixxer's Avatar
2086
Drives: nothing fast
I have JetHot coating on my turbo,both hot side&cold as well as both dump pipes. No issues at all going on 10yrs
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582)
Gone but not forgotten:
-'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG
      10-12-2023, 04:57 AM   #10
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
I have used Swaintech with older cars, VW A1 chassis stuff and BMW E30 E36 stuff without issues. I live in the NorthEast so it was a plus on having them coated they did not rust.
      10-12-2023, 09:26 AM   #11
Clark_Kent
Clark_Kent's Avatar
2307
Drives: Retired
I've used Jet Hot on an UEL exhaust manifold and uppipe on an STi many years ago. No issues and would do it again.
      10-12-2023, 05:57 PM   #12
Dasky_spas
Drives: Bmw
I bought used heat shields from ebay and had them heat treated as well to better contain the heat. You may to do the same.
      10-13-2023, 02:55 PM   #13
x622
Forced Induction Connoisseur
x622's Avatar
1189
Drives: 23 X5MC / 23 720s
Find a local coater in your area. Literally google "powdercoating" on google maps and call places and ask if they do coating on exhaust manfiolds with cerakote.
Done and done. Jethot is garbage now as others have mentioned and swaintech is just an old brand.
You don't need to send out your parts anywhere unless you live in the sticks with no coaters around.
Oy vey, look at all these shekels
