10-06-2023, 01:22 PM | #1 |
Battle Tactician
453
Rep 306
Which o2 spacer to use for downpipes?
Anyone here installs catless downpipes and use some sort of spacers that didn't throw up any CEL's?
About to get my downpipes installed and would rather not have any CEL's if possible. Not tuning this year so can't code them out.
YouTube & IG: @Dailydownshift
Current: TR G87 Stick Previous: LBB 16' M2 | 20' Corvette C8 | AW 18' M2 | AW 20' M2c | Last edited by DailyDownshift; 10-06-2023 at 01:22 PM.. Reason: Formatting |
10-10-2023, 09:35 PM | #2 |
Rep 372
big daddies garage... used on both my s58s and many others... never had cel
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten 2008 BMW 135 - 10.9 @ 131 2016 BMW X6 |
Info@mad-us.com1924.00 roopih0.00 |
10-14-2023, 06:06 PM | #3 |
Battle Tactician
453
Rep 306
Awesome, looks like they have a ton of them on their site. Can you link me the exact ones you used for the s58? Much appreciated btw!
Current: TR G87 Stick Previous: LBB 16' M2 | 20' Corvette C8 | AW 18' M2 | AW 20' M2c | |
roopih0.00 |
11-17-2023, 08:44 PM | #4 | |
Rep 3,965
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
11-26-2023, 03:36 PM | #5 |
Rep 192
You do know by not having the sensor in the exhaust stream you are restricting the function of the O2 sensor from accurate measurement to control fuel mapping the rear sensor is only looking to see if the cat is working efficiently you only need to code out the rear sensor
01-20-2024, 02:04 AM | #7 | |
Pip
21
Rep 42
Drives: 2023 BMW M240i xDrive
01-20-2024, 02:06 AM | #8 |
Rep 192
Why would you need to do anything to the sensors at all they are both needed to make the car run well with good performance they only affect performance when they do not work correctly or send the correct info to the ecm
aerobod3625.50 |
01-20-2024, 02:10 AM | #9 |
Pip
21
Rep 42
Didn’t you just say thought that the rear sensor is only used to check for cat functionality. That shouldn’t affect fuel mixture or anything else.
01-20-2024, 02:14 AM | #10 |
Rep 192
If the front sensor is having slow response but not causing a lean or rich condition the rear sensor can make corrections and will set a code
03-28-2024, 01:15 PM | #12 |
Rep 4,923
The two rear sensors need to get some exhaust gases by them. In the video above I believe he was using catted spacers with a catted downpipe and was not getting enough flow to the sensor to get a proper reading.
This wouldn't be an issue with catless.
03-28-2024, 02:02 PM | #13 |
Rep 105
So, what's the final verdict for catless DP? Spacers on all the 02 sensors? I keep almost pulling the trigger on this, lol
03-29-2024, 02:40 PM | #14 |
Rep 4,923
You need 2 catted spacers on the lower o2's only.
WhiteRqbbit79.50 |
