BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      10-07-2023, 03:37 PM   #1
mynameisnick4
Drives: 2023 M2
Aftermarket TPMS Sensors
Has anyone installed or know which aftermarket TPMS sensors will work with the G87? I checked some BMW parts sites and it looks like the OEM part number is 36-10-6-877-937 and I found these on Amazon:
https://www.amazon.com/dp/B08D5MVRN1/
According to the listing it says they should work with that BMW part number.
emm2wc1.50
      10-07-2023, 05:58 PM   #2
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Most aftermarket ones will require programing. If you have the programming tool, you are good to go.
      10-08-2023, 12:22 AM   #3
mynameisnick4
Drives: 2023 M2
I'm assuming it works similar to how it did in the F87. When you switch wheels/tires with different TPMS sensors, you just have to to do the reset/relearn function from within the tire settings. It was pretty trivial in the F87 (as long as the new TPMS were compatible.)
I'm assuming the ones on amazon will work but it would be nice to have confirmation since getting incompatible ones would be a massive pain the in the ass to replace.
      10-08-2023, 12:46 AM   #4
billspreston
billspreston's Avatar
356
Drives: G87
Using G87 programmed Huf IntelliSens here, connected up without issue.
///M TOWN32852.00
71dsp108.00
JTO245924.00
      10-08-2023, 11:35 PM   #5
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
I have been providing many forum members with Huf TPMS.
All been working and happy with it.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for everyday DEAL!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL and more...
Accepting - Visa, MasterCard, American Express, Discover, Paypal, Venmo, Cash App, Amazon Pay, Affirm.
///M TOWN32852.00
Ronin761698.50
JTO245924.00
      11-20-2023, 05:16 PM   #6
mynameisnick4
Drives: 2023 M2
Update to this topic, the TPMS sensors I linked did not end up working. I tried the relearning TPMS process in the idrive settings and it acts like it goes through the process but eventually hangs around 50% then fails.
r33_RGSport13880.50
      11-26-2023, 05:07 PM   #7
mynameisnick4
Drives: 2023 M2
One last update to this saga. I was able to get access to a high end TPMS sensor tool and resolve the issue. This is what I did.
  • First I tried to scan the sensors using the BMW M2 2023 option in the tool, it did not find them.
  • I then tried to do the same but with the Toyota Supra 2020 option because I remember in the reviews someone saying these worked fine for that car. It was able see all the sensors but one.
  • I used the tools reprogram feature to see if it could see the sensor that wasn't reading and it could. I then programmed it to the 2020 Supra option. I did this instead of trying to reprogram them all to the 2023 M2 option because of how the car behaved when I originally tried to program them. It would act like it was working but then hang and eventually fail. This behavior would make sense if it was able to see all of the sensors but the one that apparently wasn't programmed at all.
  • After reprogramming the one sensor I drove the car to do the relearn from iDrive and after about 2-3 miles, it finished the relearn and worked just fine.
So the TL/DR for this is: These sensors will work IF they are all programmed correctly as per the listing..
      12-08-2023, 10:49 PM   #8
Bearded-Driver
Drives: BMW M2 (G87) and X3m40i
Anyone know the part number for the Huf ones or OEM?
      06-05-2024, 09:40 PM   #9
71dsp
71dsp's Avatar
Same here. Picked up some pre-programmed G87 HUF TPMS sensors and had them installed in my new wheels. The new sensors connected immediately without issue.
      06-06-2024, 07:57 AM   #10
Ronin76
Ronin76's Avatar
Drives: 2018 Tesla Model 3
So these things are nit plug and play? Oh geez! I will eventually need some for my winter wheel/tire set.
      06-06-2024, 12:52 PM   #11
71dsp
71dsp's Avatar
https://www.ebay.com/itm/39507877223...mis&media=COPY
These are the ones I bought. I would have ordered from Apex when I bought my wheels, but they were out of stock.
I just told him that it was for a 2024 G87. Recognized the new wheels immediately. Was pretty seamless.
Ronin761698.50
      06-06-2024, 01:15 PM   #12
Ronin76
Ronin76's Avatar
Thank you for this man!! Much appreciated!
71dsp108.00
      11-12-2024, 09:12 AM   #13
tapis
Drives: 2024 M2 & 2023 i4 eDrive35
Just to add to this thread, I was about to purchase a set of OEM TPMS from eBay and stumbled upon your post. I purchased the ones you linked from Amazon, and they worked immediately! Thank you for saving me a few hundred bucks
ourlee1643.00
      11-18-2024, 09:21 PM   #14
FrankieNuo
FrankieNuo's Avatar
Drives: 23' G80
2023 Bmw M3  [8.87]
I have 2 sets from Ben and no issues!
r33_RGSport13880.50
      11-19-2024, 01:26 AM   #15
Whytar
Whytar's Avatar
Australia
75
Drives: 2025 Portimao G87 M2 LCI
If you read the production description on this website they mention them being pre-programmed for plug-and-play...
https://southernbm.com.au/products/a...6b?category=80
      12-07-2024, 12:15 AM   #16
Ronin76
Ronin76's Avatar
Anyone know if the TPMS sensors on Apex's website come preprogrammed?
      12-07-2024, 06:43 AM   #17
IanH
Drives: '25 M240xi
I got a set of 4 tpms from tire rack, not sure the brand but they are not oem and not expensive, but I bought them separately from the wheels and tires. Had the mount and balance done at an independent motorsports shop. No coding or pairing was done to the sensors or vehicle.
When I installed the wheels on the car 2 weeks later, the sensors were automatically detected and everything works fine.
2025 M240i Xdrive TNM - Dinan Springs - CF Goodies - More in process
Ronin761698.50
      12-07-2024, 12:12 PM   #18
aerobod
Car Geek
aerobod's Avatar
Some aftermarket sensors from companies such as Autel have the capability to use a generic sensor and configure it to meet specific car manufacturer needs, but that is covered by the programming tool that the sensor vendor uses. Should be plug-and-play for all BMWs and many other manufacturers, when using the generic sensors.
