10-10-2023, 06:01 PM | #1 |
Rep 750
All - I decided to create this thread to hopefully unify any conversations regarding iDrive 8 (OS8) and BimmerCode. There are currently several threads with information spread all across this forum. Hopefully this thread can be used for all discussions moving forward for an easy reference point.
Prerequisites:
Process:
Coding Examples: To kick off the conversation, here is a list of all of the “modifications” I am currently running that were coded via BimmerCode. Startup warning message delete: - Headunit > Warning at startup > “Not active” Mirror tilt value: - Body domain controller > Mirrors > Auto mirror tilt value > select percentage, I chose 30 Comfort+ drive mode: - Body domain controller > Expert mode > FesComfortWorldMode1 > “ComfortPlus” > CODE - Body domain controller > Default Driving Mode (optional) - Headunit > Expert mode > Fes_Comfort_Plus > Aktiv - Eco_Conf_Steering_Comfplus > Aktiv - Eco_Conf_Attenuation_Comfpl > Aktiv - CODE Hazard with emergency braking: - Body domain controller > Lighting > Hazard warning… Seat belt reminder off: - Advanced crash safety module > seatbelt reminder (driver and passenger) Rear camera zoom (top down view of rear) - Headunit > Expert mode > Macro_trailer_coupling > active Anti Dazzle Headlights: - Body domain controller > expert mode: - La1: - C_BLC_Pre_Ena = enable - LUT_FLC_forwardlighting_Y = AFS - La2: - C_Afs_eco_level3_ena = enable - C_Afs_ena = enable - La3 - Lut_afs_codrv_hor = standard/init - Lut_Afs_Drv_hor = F040_G005… - C_Clc_curv_v2 = ECE - C_Clc_curv_v3 = ECE - C_Clc_Ext_Ena = enable - C_Hba_Dim_ena = enable - C_Hba_Gfhba_ena_v_hi = standard - C_Hba_Gfhb_ena = enable. - Code. Change default ambient lighting color: - Body domain controller > First color (default color is what is getting set) - Color contour = set - Color = set Rolls Royce / older BMW chimes: - Receiver Audio Module > Signal Tones No longer working after a recent iDrive update: Auto start/stop memory: - Engine control unit > Auto start stop function memory > Active - Auto start stop function > Not active Most headunit/gage cluster related items appears to be locked at the moment. For example, coding top speed (V max) and ///M style gage cluster layout. This is possibly encrypted in iDrive 8 but hopefully support may come in the future. Last edited by TJZ67201; 10-11-2023 at 01:29 PM.. |
14
grooveK122.50 redcars103.50 Coconut771.50 darkvader0132.00 apez669.50 BlueLEDz153.00 Fidiman114.00 Sonic RR129.00 cannockwolf884.50 nickmaguire44.00 a358970751117.00 fortysecond51.00 VegasG42390.00 Kay.Say15.00 |
10-10-2023, 09:24 PM | #2 |
Rep 172
Thanks for posting this in one place. Like many, I’ve pieced together the different options from multiple post.
There are reason why I avoid doing updates, always regret I have mine set to start in sports individual. The anti dizzel headlights is amazing. I often wonder what it looks like from the prospective of the car in front of me. I tried Hazard with emergency braking, but got some lighting error. Was able to fix it by reverting to a backup. Possibly I selected the wrong setting 🤷‍♂️ |
TJZ67201844.50 |
10-10-2023, 10:36 PM | #3 | |
Rep 750
I didn’t get any errors when I coded the hazard lights but I also didn’t test it out yet. Will report back once I’m able to test some more |
10-11-2023, 01:33 AM | #4 |
Rep 93
I’ve had my share of WiFi adapters but by far the fastest and most reliable is a OBD to USB-C adapter!
I’ve never entered diagnostic mode before coding. What is the purpose of that? ASS is permenantly disabled for me - I’ve never had an issue with it through all ID8 software updates. Not sure why my car is an exception while others are stuck with it. I code ASS disabled + ASS memory. |
Sonic RR129.00 |
10-11-2023, 07:39 AM | #5 | |
Rep 1,881
10-11-2023, 07:59 AM | #7 |
Rep 389
I tried to change ambient color but it wouldn't work at all
It DOES work. Code the Bronze to whatever color you want from the available options—its the top, 'default' color. Then when you select it in iDrive later, the onscreen menu still shows the Bronze, but the ambient lights will actually be the color you coded. You can see the purple in these photos. Last edited by PRINCE THUNDERNIGHT; 10-11-2023 at 08:49 AM.. |
10-11-2023, 09:04 AM | #10 |
Rep 86
There was something we could code to improve the sound of the Harmon Kardin system (maybe all of them?). Does anyone have knowledge about that one? I was looking for it and can't find it now.
10-11-2023, 09:09 AM | #11 | |
Rep 149
- Eco_Conf_Steering_Comfplus > Aktiv - Eco_Conf_Attenuation_Comfpl > Aktiv I get the other comfort plus options relate to suspension damping. Is comfort plus steering even lighter than standard comfort steering? And what is attenuation? I assume these can be not set to active if not wanted? I have no desire for the steering to be any lighter. |
10-11-2023, 09:52 AM | #12 | |
Rep 750
I notice that you have to turn the wheel slightly more with Comfort Plus steering, for example, when taking a corner at speed on the highway. It doesn’t feel any lighter but slightly more input is required. In my opinion it feels like the steering is less sensitive to input. The plus side of this being that you need to micro-correct slightly less to stay on center when cruising for a long ride on the highway. My overall opinion of Comfort Plus is very positive. Noticeably softer suspension but almost to the point where it feels unsettling when taking corners at speed (I suffer from the “rear suspension thump” issue but almost never hear it with C+). Shifting is also slightly different, smoother as it hold gears slightly longer instead of trying to be as efficient as possible. Trans also decouples from the engine when stopped so you don’t feel drivetrain vibration |
10-11-2023, 10:42 AM | #13 | |
Rep 149
I coded B&W to mine. To my ears, it's only marginally better to my liking using the Concert setting. It's not tremendously different, but slightly more to the overall sound profile I prefer. Some do not like it, some do. It's worth a try. |
darkvader0132.00 |
10-11-2023, 01:16 PM | #14 | |
Rep 750
darkvader0132.00 BlueLEDz153.00 |
10-11-2023, 02:04 PM | #15 | |
Rep 149
I bet I would get even cleaner results with lower surround (mine is set to mid) but I've been liking the mild surround effect, it adds some room to the sound and doesn't sound like it's only in your ears. It has baffled me that other OEMs don't offer a multiband EQ as an "advanced" option that you could choose. Some cars only offer bass and treble, not even mid. I'm sure cost saving comes into play since very few consumers would use it, but honestly how much can it possibly cost to program? I'm very glad I have the option. |
TJZ67201844.50 |
10-11-2023, 06:38 PM | #18 | |
Rep 172
10-11-2023, 06:40 PM | #19 | |
Rep 17
10-11-2023, 06:42 PM | #20 |
Rep 172
Whatever color you have selected in ID8 is the color you can code.
For example if you want to change emerald to something else, then select emerald before you start coding. So if there is a default color you want to keep, don’t have that selected when you code your new color. If you selected the wrong thing you can always revert from the automatic backup. |
10-11-2023, 06:42 PM | #21 |
Rep 750
10-11-2023, 08:35 PM | #22 | |
Rep 107
