BMW M2 Forums 2023+ (G87) Wheels | Tires | Suspension | Brakes | Chassis
      10-15-2023, 02:05 PM   #1
mzimand
Drives: 2023 M2
H&R VTF - amazing
I installed the H&R VTF springs the past week and put about 300 miles on my local back roads. I decided to go with H&R because a a friend who owns a well known local shop called AR Motorworkz recommended it (thanks Ron). He had gone through several suspensions on his G80 and settled on the H&R VTF.
I did not really care about the stance as much as wanting improvement in handling. I did about 3000 miles on the stock suspension. I also added 15mm/12mm spacers. I am more then happy with the updates. Lowering the center of gravity of the M2 has improved the handling characteristics even more then I had hoped. I use my M2 as my daily but work from home and put 90% of my miles in the mountains and canyons of SoCal.
My car came with the PZERO’s and they had 3000 hard miles on them prior to the H&R’s being installed. I have a new set op PS4 tires ready to install but wanted to see how the H&R felt with the PZERO’s. The Perelli‘s we’re wearing badly on the front outer edges but lowering and spacing the wheels probably added some much needed camber. I will get an alignment this week (wanted springs to settle before alignment). I can already see the tired wearing better. I had a G42 xdrive prior to the M2 and basically did the same mods on it. I actually reused the spacers from my G42 on the M2.
Updated with pictures after a wash.
      10-17-2023, 10:38 AM   #2
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
I had the H&R VTF on my G82 M4 RWD and also got the H&R VTF on my G82 M4 X-drive, both kits are excellent
https://x-ph.com/sale/
Phone number 702-494-9435
mzimand147.50
      10-19-2023, 03:12 PM   #3
mzimand
Drives: 2023 M2
I updated with pictures and can recommend the H&R to anyone looking for an adjustable kit for their car.
      10-20-2023, 04:36 PM   #4
jay1k2
Drives: '23 BG G87 M2
Is the suspension set as low as it will go? I just got the kit and will be installing it soon.
      10-21-2023, 12:46 AM   #5
mzimand
Drives: 2023 M2
Not even close to as low. I only did 1.2” front and 1” rear. Has another .5” or more. I think the H&R has one the best ranges. My buddy has his much lower and still was not all the way.
jay1k287.00
      10-25-2023, 09:02 AM   #6
tylerdurdem
Drives: 2023 BGM M2
Anyone tried the H&R springs yet?
      10-25-2023, 10:36 AM   #7
mzimand
Drives: 2023 M2
I was going to go with the H&R Springs but was talked out of them by someone* who had them on their car and ended up replacing them because the rear was a little bouncing and also they did not lower the car enough.
*he has a shop that specializes in BMW's and told me the VTF was much better and uses them on all his cars.
      10-25-2023, 11:12 AM   #8
mike@x-ph.com
+ for the H&R VTF, its the best option for a street car in my opinion
      06-08-2024, 11:29 AM   #9
G80_Jahre
Drives: 2023 M3 50 Jahre
These look great. I actually just installed these (pics to follow) but I was curious if anyone else ran into the same issues I did when attempting to adjust after the install? I am attempting to raise the rear by about 1/4' or so however the top mount (piece that is threaded and sandwiched to the body) continues to spin when I move the actual collar, resulting in no adjust adjustments, and just spinning the entire unit.
2016 BMW M3 - Individual Azurite Black Metallic
2023 BMW M3 50 Jahre - Interlagos Blue
      06-08-2024, 01:05 PM   #10
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Ron is cool.
I went to Supreme (Ron’s friend) just because I got a slightly better price. I am also on H&R VTF.
jay1k287.00
