10-16-2023, 06:30 PM | #1 |
Rep 21,735
▀▄ eas | Ohlins - Road & Track DFV Coilover System - BMW G87 M2
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Öhlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit. Because DFV opens more quickly and easily on minor road imperfections, ride comfort is surprisingly supple and more akin to an OEM strut than a coilover set-up. Over undulating surfaces, the compliancy of the R&T units allows the car to crest bumps and pot-holes, whilst still keep stable and in control. Traction is always maintained at its optimum level. When comparing suspension, why settle for second best? Product link https://europeanautosource.com/colle...-bmw-g8x-m3-m4 When adjusting ride height on coilover units, it’s worth comparing how it’s done. On many inferior designs, height is adjusted by raising or lowering the lower spring platform. This has the effect of compressing or extending the spring, which can limit the suspension travel that may cause topping out. The Öhlins method is to leave the spring seat in its perfect position, whilst the lower flange spins easily on the threaded body, to allow you to adjust with absolute precision whilst maintaining the perfect characteristics that we took so long to design in! Once you’ve set it all up, the adjuster simply locks off to maintain your exact settings. Dampers will get hot. That’s one thing that you can be sure of. As the piston moves within the damper, it generates friction – and therefore, heat. Although we can’t stop heat, we can deal with it, and this is yet another way that Öhlins differs from the competition. As the heat increases, the viscosity of the damper fluid can change, altering the car’s handling characteristics. Our unique needle bleed valve expands with temperature, closing the gap that the fluid travels through, maintaining a consistent damping rate. The best thing of all? You won’t even notice! All you’ll feel is that the car responds consistently, lap after lap, turn after turn. Allowing you to concentrate on braking points and apexes whilst the Öhlins technology takes care of the damping. These kits all work well "out of the box", but there’s still plenty of adjustment for you to set things your way. You like stiff and reactive? Or soft and forgiving? It’s all there. Too much low speed rebound damping can have an adverse effect on grip, so the easily accessible adjuster at the base of the Öhlins units allows small, but positive increments of fine tuning, so you can take into account every single parameter. Sounds complicated? Nothing could be further for the truth. Just a few clicks either way from our factory settings will soon have your car responding precisely to your inputs and driving style. Most of the Road & Track McPherson struts also feature camber adjustable upper and lower mounts to give you the possibility to fine tune your wheels for the right occasion – whether you want to go for a ride in your neighborhood or take your car for a spin at the track on a weekend. Features - Dual Flow Valve (DFV) technology - Fully rebuildable - Adjustable ride height - Individually adjustable dampers - Wide range of dampening settings (20+ defined clicks) - Corrosion tested with salt spray (ISO 9227) - 2-year limited warranty - Approx. 10 kg weight saving compared to original chassis Specifications - Front McPherson strut, upside down, rear conventional shock absorber - Regulation of rebound and compression damping via an adjuster - Spring preload adjuster - Height adjustable (F:/R: 20-25mm) - Use with original top mounts Vehicles Supported BMW G87 M2 Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-12PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 10-17-2023 at 10:55 AM.. |
10-23-2023, 08:02 PM | #2 |
Rep 18,828
Ohlins Road & Track kits are in stock and shipping now! Contact us to get your set today!
10-27-2023, 01:27 PM | #3 |
Rep 18,828
BSM M2 shows off its new look with a set of perfectly fitted set of Ohlins Road & Track Coilovers. Contact us to get your set today!
11-16-2023, 06:44 PM | #4 |
Rep 21,735
Ohlins coil over ready to ship
PM today to get yours
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-11-2023, 06:23 PM | #5 |
Rep 21,735
Ohlins coil overs ready to ship
01-08-2024, 04:59 PM | #6 |
Rep 21,735
Ohlins coilover kits ready to ship
01-23-2024, 06:43 PM | #7 |
Rep 21,735
Ohlins coilovers ready to ship
02-06-2024, 05:45 PM | #8 |
Rep 21,735
Ohlins coil overs ready to ship out
02-15-2024, 06:42 PM | #9 |
Rep 21,735
03-27-2024, 06:17 PM | #10 |
Rep 21,735
Ohlins coil overs kits ready to ship out
Today, 06:18 PM | #11 |
Rep 21,735
Ohlins R/T ready to ship
