10-18-2023, 05:56 AM | #1 |
Rep 49
Long term side effects of HAS kits?
I've been researching and couldn't figure out if it's worth lowering the car? I've purchased the HAS kit and am about to get it installed, but I'm still not sure what the long-term cons of having it will be.
Have you guys faced any issues so far? In the future if I want to adjust the height (higher or lower) do I have to consider wheel alignment every time I adjust the height? |
10-18-2023, 08:21 AM | #2 |
Rep 2,987
Drives: A Family Sedan
Effects are unknown at this point. Because BMW offers it, it’s not a bad assumption to believe the shocks are made to withstand the different springs.
And, yes, alignment is needed after a change in height. |
10-18-2023, 09:30 AM | #3 |
Car Geek
3626
Rep 3,594
Tyre life is likely to be one compromise if the car is lowered the not driven aggressively and/or not realigned, but if the car is used on the track you may get better tyre life than with the original height.
From an alignment perspective, have it done with the car at the most used road height, take measurements of the position of the adjustment ring or mark the threads with paint at that height. If you use this as a reference that you can easily return to, then a more aggressive drop should add camber and toe-out, which is what will help preserve the outer edges of the tyres on the track. If left in the lower position for normal road driving, then the inner shoulders of the tyres will wear out prematurely. |
10-18-2023, 10:24 AM | #4 |
Joint Chiefs of Staff
24198
Rep 190,807
I have been using HAS kits for years, never had any issues or long term side effects.
thinking64.50 |
10-18-2023, 12:11 PM | #5 |
Rep 871
By issues, what do you mean? Do you mean usability issues like scraping more often, not having as much clearance for some jacks, etc....well that depends on how much you lower it. I personally would not lower it more than 25mm/1", and would prefer even slightly less, like 15-20 mm.
For reference on P-cars when you go to PASM you go 10mm/0.4" lower. Some cars that have PASM standard you go to PASM sport and lower another 10mm/0.4". So 0.8"/20mm is the max total lowering. And then they (like GM on the C8) sell you a front end lift for $4,000, so you can raise the nose as needed to avoid scraping. LOL On the other hand, I see slammed BMWs (2" down) driving around New York City and their disgraceful, pot hole infested streets - I don't know how they do it, but they do it. If you are asking about long term damage to the car, so long as it is a reputable kit that is not bottoming out and exceeding the shocks compressed range, or unseating the springs on the drops, there is really nothing that can be damaged long term.
G87 M2 BSM On Order
thinking64.50 |
10-18-2023, 12:56 PM | #6 | |
Rep 18,823
As aerobod mentioned, you can always mark where the adjustment collars sit if you want to make incremental adjustments to your liking, but it's something that's not done often unless a signifigant change is being made (ie: different wheels or right height adjustment). Most times it's set it and forget it.
thinking64.50 |
10-19-2023, 08:04 AM | #9 | |
Rep 49
Don't really care about tires. I was more concerned about having any damage to the shock absorbers because the HAS kit springs are usually stiffer. But thanks for clearing this up |
10-19-2023, 12:54 PM | #10 |
Rep 105
Is the HAS kit considered more visual than performance? I've seen some mixed things on its effects performance-wise. I originally wanted to go this route, and while it's more of a daily than a track car, performance matters to me. I was debating if I should stay stock until I'm ready to jump into a proper coilover such as KW v3/4 or similar. What are everyone's thoughts on this?
10-19-2023, 01:12 PM | #11 | |
Rep 18,823
It really comes down to if you have any prior track experience and/or if this is a road you want to continue down, as it can be pretty addictive. If only seeing a couple of track days a year, the Ohlins R&T setups are fantastic option. For the more focused driver, the KW V4 would be a better choice or even better - the V4 Clubsport. Feel free to PM/email me if you have any additional questions, or need recommendations.
10-19-2023, 01:40 PM | #12 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
10-19-2023, 02:22 PM | #13 |
24198
Rep 190,807
10-19-2023, 08:36 PM | #14 |
Rep 140
The only call out I would add is that be sure you get it installed by a good shop. There are cases of blown struts from after the install. Seems to go back to people not having the right tools and or technique when installing. If you are having a dealer install it, then you also get a warranty on the installation which could be worth it.
thinking64.50 |
10-20-2023, 03:09 PM | #15 | |
Rep 49
10-21-2023, 10:50 PM | #16 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
I've had mixed results with lowering springs like Eibach and H&R, but the bottom line is unless the shock valving is perfectly matched to the springs, you are not going to get significant improvement over stock ones.
MP HAS should work well as long as it does what it's advertised to do.
Pass me if you can.
thinking64.50 |
10-23-2023, 08:42 AM | #17 |
Rep 47
Are any ECU suspension tuning changes needed after a HAS kit is installed to let it know it's been lowered?
My local BMW independent specialist mentioned that he lowered a client's previous generation M2, and with each adjustment of the HAS kit, the ECU needed an adjustment. |
10-23-2023, 09:16 AM | #18 | |
Car Geek
3626
Rep 3,594
M2siast5876.00 |
10-27-2023, 01:58 PM | #19 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
