10-26-2023, 10:17 AM | #1 |
Rep 49
2023 G87 M2 Bluetooth iPhone failure
This thread is just to help my fellow G87 M2 owners. I recently had my iPhone 15 pro max fail to connect to the BMW Bluetooth. The Bluetooth toggle in the BMW would not allow you to switch it on. Searching the internet found nothing to help.
The solution is to perform a soft reset to the radio system only; press and hold the physical on/off radio button until the screen goes black, release and then press the button to turn on. Bluetooth should work now. |
10-26-2023, 10:22 AM | #2 |
8130
Rep 10,606
Yep, it's the most common issue I see with new BMW's.
If the soft reboot doesn't work, try restarting your phone. If neither work, delete and start from scratch. |
10-26-2023, 12:12 PM | #3 |
Car Geek
4253
Rep 3,902
Not only BMWs in my experience, probably happens about twice as often in our 2021 Macan and used to be even more frequent in our 2016 Golf R. Also has happened in Peugeot and Mercedes rental cars that I have driven over the past few years.
deleted_807865_k0a0df9ee6877.50 M2Sky115.50 |
10-26-2023, 12:18 PM | #4 | |
8130
Rep 10,606
I think the issue is the constant IOS updates + foreign system +vehicle updates and things don't always sync up together. |
10-26-2023, 12:34 PM | #5 | |
Car Geek
4253
Rep 3,902
deleted_807865_k0a0df9ee6877.50 |
10-26-2023, 02:52 PM | #6 |
Rep 49
If the vehicle’s Bluetooth can be toggled off and on then it will more than likely be your phone. In my case the vehicle’s Bluetooth stayed off no matter how much u tried to turn it on it was unresponsive. In that case which was mine I did the soft reset n it worked after.
11-08-2023, 02:27 AM | #8 |
your average JAMF
3504
Rep 4,181
Drives: '21 M2 Comp, '19 Golf R
The fix is out today in 17.1.1.
Apple says the iOS 17.1.1 update addresses an iPhone 15 charging problem, seen by some BMW and Toyota Supras drivers. Apple has acknowledged that the wireless charging systems in these cars can deactivate the iPhone 15 range's Near Field Communications (NFC) capabilities. https://appleinsider.com/articles/23...-iphone-issues
'21 M2 Comp
'19 Golf R |
11-29-2023, 07:59 PM | #9 | |
BMW nerd
91
Rep 301
2024 Zandvoort M2
1995 Schwartz 840Ci 1984 Arktisblau 528e 1973 Baikalblau 3.0 CS |
12-02-2023, 03:20 AM | #10 |
Rep 42
For those with iPhones, you can setup automations via the shortcut app on your device.
For instance, I have mine to automatically begin playing YouTube Music upon connecting to CarPlay and also to give me the option to accept directions to drive home. I haven’t had any CarPlay issues in my four months of ownership. |
12-02-2023, 08:41 PM | #11 | |
Rep 47
I’ve only had to reset once in 2 years on my G05 X5 but that was mostly android auto use. M2 not had an issue yet. One thing I’ve noticed between apple car play and android auto is you get google maps on the HUD with android auto. |
aerobod4253.00 |
