10-30-2023, 07:48 PM | #1 |
Rep 251
Removing Battery for Winter
My M2 will be stored for a few months as I holiday abroad for winter. I plan to remove the battery and store it in a temperature controlled environment.
Just wondering if I can expect any grief when I re-install the battery? Will the vehicle remember all its settings? I hope I don't have to go through a reprogramming session when I re-install the battery. |
10-30-2023, 08:00 PM | #4 |
Enthusiast
325
Rep 309
Drives: 2022 230i M Sport
I have heard that BMWs don't like batteries pulled and putting one back in requires the dealer...I'd double check with the dealer. My friend's experience was with an E92 M3 though.
M_Power Rob4594.00 |
10-30-2023, 08:14 PM | #5 | |
Rep 251
That's certainly an option. As I would hardwire a tender, I would still prefer to disconnect the battery during the installation. Again, any issues to anticipate when reconnecting the car battery? |
10-30-2023, 09:30 PM | #6 |
this is the way
20163
Rep 8,974
10-30-2023, 09:37 PM | #7 |
Rep 251
Thank you.... I did see that before.
But again, if I proceed to hardwire my tender, I would prefer to disconnect the battery for a short period while I complete the wiring. Has anyone disconnected their M2 battery? Are there any considerations to be aware of when re-terminating? I am aware that a NEW battery needs to be registered....with hope, that wont be necessary for this procedure. |
10-30-2023, 09:49 PM | #8 | |
Rep 251
I'll let you know how it works out. |
deleted_807865_k0a0df9ee6877.50 |
10-30-2023, 09:50 PM | #9 | ||
this is the way
20163
Rep 8,974
Registration is only required for a new battery, you don't need to (nor should you) do that when reconnecting your battery. |
10-30-2023, 10:02 PM | #10 |
Car Geek
4294
Rep 3,948
Trogster526.00 deleted_807865_k0a0df9ee6877.50 |
10-30-2023, 10:10 PM | #11 | |
Rep 251
If that's the entire impact of pulling a battery, we're good! |
fanofbmwe462957.00 |
10-30-2023, 10:15 PM | #12 |
Car Geek
4294
Rep 3,948
It could mean you have to incur a for-fee update to the maintenance dates at the dealer, though. Without that update you may end up not getting all the free maintenance items in the 3 year included maintenance period.
10-30-2023, 10:19 PM | #13 | |
Rep 251
I trust the service clock will resume when the battery is reconnected? |
10-30-2023, 10:20 PM | #14 |
Car Geek
4294
Rep 3,948
That would be correct, would only be a problem if you are pulling the battery for the winter. You may end up with having to do things such as resyncing the window pinch setting, though.
10-30-2023, 10:23 PM | #15 |
this is the way
20163
Rep 8,974
If you don't mind, can you explain why you insist on disconnecting the battery when installing the hardwiring? My curiously is getting the best of me.
10-30-2023, 10:29 PM | #16 | |
Rep 251
The tender leads will be terminated in the engine compartment. Of course the negative lead will terminate at chassis ground, and the positive lead will terminate at the 'hot' jumper terminal. The 'hot' positive jumper terminal is in close proximity to metal components (cross brace). And although I have a steady hand, I would rather not risk a short to chassis when I remove the jumper stud when I secure the tender lead. Safety first |
10-30-2023, 10:38 PM | #17 | |
this is the way
20163
Rep 8,974
To each their own. |
Nuhi6.00 |
10-30-2023, 10:48 PM | #18 | |
Rep 251
The risk lies with the spanner on the jumper stud. When in contact, the entire spanner is conductive and a potential short path. You'll have to clarify how removing the negative battery lead in the trunk risks a short? Last edited by Trogster; 10-30-2023 at 10:55 PM.. |
10-30-2023, 10:54 PM | #19 |
this is the way
20163
Rep 8,974
10-30-2023, 11:10 PM | #20 |
Rep 251
Indeed.
I have rubber sheets that can be located in the engine bay to minimize risk. Plus I can insulate my tools with heat shrink tubing. However if removing the battery negative terminal alleviates all risk with little to no impact to vehicle memory settings, that seems the sensible approach. |
10-31-2023, 08:15 AM | #22 | |
Rep 1,711
My advice would be to stop in at the local BMW dealer service department and ask if the car would need shop power while the battery was disconnected. |
Trogster526.00 |
