BMW 5-Series (G30) Forum Cosmetic Maintenance: Wash, Wax, Detailing, Repairs Cleaning Engine bay
      11-05-2023, 11:32 AM   #1
oldtexasdog
Drives: 2020 M550I X Drive
Cleaning Engine bay
What is the best way to clean the engine and bay area. Just want to be safe my M550
      11-15-2023, 09:22 AM   #2
oldtexasdog
No one cleans there engine?
      11-17-2023, 03:34 PM   #3
DrSteveB
Drives: '18 540d, '18 X3, '10 335d
This response will likely trigger a swarm of replies so I have donned my helmet and armored motorcycle gear in anticipation.
Here goes:
I start the engine and leave it running during and after this process.
Before the engine is warm, I use the "soap" attachment on my pressure washer and spray everything with car wash soap in the reservoir - making sure nothing dries and that all surfaces I can get to are soaped up and nothing dries before moving to the next step.
Next, I use the 45º (I think) attachment and carefully rinse everything I can get to which is quite a bit. I adjust the distance and duration of the pressure washer tip from each engine part, depending on what the part is - use your judgment.
I let the engine run until everything is dry.
That's it!
I have been doing this long before there were pressure washers (maybe 50 years) and never had a problem or experienced a bad outcome.
      11-17-2023, 08:32 PM   #4
admranger
Retired Curmudgeon
admranger's Avatar
Drives: ‘19 X3M40i, ‘18 m550i
Just don’t spray chemicals or water directly at the electrical connectors and don’t spray water on a hot engine and you’ll be ok.
I just used all purpose cleaner on a rag and clean it that way and then rinse after cleaning. Starting the engine and letting it get hot is a good idea to help drive off any wayward moisture.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS
      12-19-2023, 11:04 AM   #5
silverydragon72
Drives: BMW M550 2021
My detailer does mine once a year when they are doing the ceramic coating Maintenace.
      02-04-2024, 05:49 PM   #6
jiggyboiswagg
Drives: 2022 BMW M550i
2022 M550i  [0.00]
Steam Clean, just had my 2021 x5 done by a detailer.
      02-05-2024, 06:37 PM   #7
jsf721
Drives: 2019 540i X M Sport
Polish angel Engine is my foto product. It’s a mild cleaner and protectant all in one.
      02-16-2024, 12:52 PM   #8
Joe-BMW33
Joe-BMW33's Avatar
7351
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
I just use my oldest MF cloths and the correct products for cleaning and finishing. P&S cleaner for any grime sprayed directly on the cloth and Duragloss Vinyl Dressing for the plastics and Car Pro Perl (uncut) for the rubbers.
Key is to keep up with it and you will never need to steam it, douse it or soak it.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
430Scud253.00
5post
