11-10-2023, 09:59 AM | #1 |
Rep 47
Are wheel spacers safe?
Called a couple shops for spacer install quotes and a few won’t do it due to complaints and safety issues. I didn’t realize it was that bad. Any thoughts?
11-10-2023, 10:12 AM | #2 |
Learning to drive again
714
Rep 321
Drives: M3CS
Cheers,
BoB |
11-10-2023, 11:31 AM | #3 |
Rep 2,987
Drives: A Family Sedan
If I had a shop, I wouldn't install your stuff that you brought with you.
I could probably test and homologate my own and install those, but that's a specific niche market of tuning. Spacers can cause issues in your bearings. Suspension issues. Wheel fitment issues. Vibration. Longer bolts can shear, especially if they are not made with the proper steel and manufacturing. Lots to go wrong for a simple "install" where the installer is held liable. It's a simple thing to do at home, though. |
11-13-2023, 08:44 AM | #4 |
Rep 105
It makes sense and doesn't make sense simultaneously, and I could never really wrap my head around the difference between a spacer and the same effective offset being any different. Not all spacers are made the same, hubcentric is important.
Albator_IIII1013.00 |
11-13-2023, 09:33 AM | #5 |
Retired Major
1013
Rep 738
Introducing a spacer adds a link to the "chain". The more links a chain has, the more sources of vulnerability there are. If you have to push the wheels out more, a more aggressive offset>spacers.
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
M2siast5876.00 |
11-13-2023, 09:37 AM | #6 |
Rep 105
That makes sense, adding a failure point. The part that confuses me is the effects on the bearings and the geometry of the other linked post. Taking the failure point aspect out of it, like if I welded the spacer to my wheel, would that be the same as changing the offset? lol
11-13-2023, 12:11 PM | #7 | |
714
Rep 321
Drives: M3CS
The additional load on the bearings, IMHO, is not significant. The bigger concern is the load increase and the amount of 'work' that the control arms, steering connectors, toe links, shocks, etc. will have to endure. There is a long-term effect. It is impossible to determine the effect without knowing the metallurgy of those links as manufactured by BMW. That being said, with the G8x, the general consensus by professional motorsports shops, including Turner, BimmerWorld, etc. is that 10-12 mm spacers appear not to cause significant issues with either the load on parts or the negative effects of changing the scrub radius. But of course, don't quote me on this or take it as gospel, I am not a spokesman for them. Also, anything above 12 mm hasn't been tested, to my best knowledge, under load. I use 10 mm spacers on my G80 and put load on them. I only have few hundred miles on them wihout issues, but we'll see in a year
Cheers,
BoB |
M2siast5876.00 |
11-13-2023, 01:46 PM | #9 |
Rep 105
It has always been an interesting topic. Often, it's just regurgitated information someone reads on the internet and not often backed by anything other than that. I've seen some purpose-built hill climb / race cars using pretty thick spacers without issue - I think the difference is the quality of the parts. Most people slap poorly fitting spacers and never check to ensure they are still torqued to specification.
I don't recommend spacers, but I'll be running spacers to hold me over until I order a proper set of wheels.
Bearded-Driver876.50 |
11-13-2023, 02:27 PM | #10 |
Joint Chiefs of Staff
24199
Rep 190,807
100% safe if installed correctly.
11-13-2023, 02:45 PM | #11 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I threw one at a person once and it really hurt them. I'd say no.
Sherlock997218.50 |
11-13-2023, 03:37 PM | #12 |
60-130 Enthusiast
1397
Rep 739
Depends on the manufacturer.
The first spacers I got were from Turner. They were unusable. They were not hubcentric and did not have a place for the wheel to mount onto. That's what I get for not researching. They're still brand new in the box at home. I can't even sell them in good conscious because I don't want someone to get hurt. Next set I bought was from Dinan. Not a knock on Dinan, I love their stuff, but I had 10mm spacers on my ZTK wheels on my M240i. The car always felt a little weird with the spacers. I don't know how to describe it other than weird. When I removed them, it was clear that the spacers were rotating inside of the wheel under lateral load. That's where the weird feeling was coming from. On my M2 I use spacers from Future Classic. They actually bolt to the hub and it's physically impossible for them to rotate. I haven't had any of that weird feeling and it's been over 6,000 miles with the stock 930Ms and the 827Ms I have now. You're mileage may vary. |
Sculpin276.50 |
11-13-2023, 07:32 PM | #13 | |
Rep 88
rons e921397.00 |
11-14-2023, 06:58 AM | #14 |
Rep 636
I went for a "conservative" 8mm all around with extended lugs. Install with wheel hangers, non seize grease, wire brush, correct torque. Take your time fitting them and your wheels and not much can go wrong.
Looks great, performs great. |
11-14-2023, 11:14 AM | #16 |
Car Geek
3626
Rep 3,594
Assuming the wheel spacers are hubcentric with both an internal counterbore to fit the BMW hub boss and an equivalent boss on the spacer to hang the wheel, they should be safe, as long as they have the right chamfers on them. As I've mentioned before, an F87 lost a wheel at a track day when the wheel stud kit studs sheared off after only a few hours of use, due to incorrect chamfering of the wheel spacer. This video explains:
