11-13-2023, 08:37 AM | #1 |
Rep 105
Braided brake lines?
I've typically always upgraded my lines to braided on my cars to give a firmer pedal feel and consistency. Since these cars use electronic braking, will you feel a difference? I've always enjoyed a heavy brake pedal, probably something I developed from sim racing haha.
11-16-2023, 10:15 AM | #2 |
Rep 130
I think these cars are brake by wire so since there is no physical connection between the pedal and the brake lines to calipers you will not feel a difference in the pedal feedback.
11-16-2023, 04:21 PM | #3 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
The teflon lining in the SS lines also helps with moisture permeation. |
k-m2-j442679.50 |
11-17-2023, 10:07 AM | #4 |
Rep 419
Drives: 21 Supra 3.0
You'll notice it on a hotlap about 50 feet too late (along with fading pads)
11-17-2023, 02:22 PM | #5 |
3847
Rep 54,376
Drives: F80 M3
11-17-2023, 02:26 PM | #6 |
Rep 419
correct me if I'm wrong but brake fluid temp, which causes expanded rubber lines (and stainless braided prevents) coincides with increased temp in the whole braking system including pad fade.
Additionally it slows moisture absorption and in normal (non-brake by wire) improves pedal feel across a wide range of scenarios including track days where fluid temps are an issue.
11-21-2023, 03:01 PM | #7 |
Rep 842
We offer Spiegler Stainless Steel Brake Lines on our site. They are DOT compliant and have a really cool swivel fitting that prevents them from binding/getting twisted:
https://www.essexparts.com/my-vehicl...pound%20Brakes You can read more about Spiegler here: https://www.essexparts.com/brake-lines |
WhiteRqbbit79.50 |
