11-18-2023, 10:49 PM | #1 |
Rep 399
DSC won't deactivate
So recently DSC will not deactivate. I can press the button or select my M2 button which has DSC turned off and the dash will show that DSC is off but as soon as I start driving it turns back on.
There are no errors or codes. Any ideas?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, SPL links, Adro wing, IRL exhaust, Verus Splitter, MAD downpipes, Bootmod3; IG:g87_43 |
11-28-2023, 09:39 PM | #2 |
Rep 399
Solved.
I am updating for those searching for this in the future. I currently do not have an EDC cable due to the dealer breaking it during an alignment and the cable is back-ordered. I had a chassis error but was still able to drive and I had full control over DSC and MDM. However earlier in the month while at the track I lost the ability to turn off DSC or use MDM. There was no error and no code that I could pick up with scanners (I don't have ISTA). If I was parked I could turn off DSC and then set MDM to whatever traction control setting I wanted but as soon as I started to move, DSC would turn back on. The week prior at the track I had full control of DSC and MDM even though I had the chassis error from a missing EDC connection. I did a lot of research and couldn't find a reason for the DSC to act this way. Tonight I got a bit impatient so I made my own EDC cable and reconnected my strut. When I went for a test drive the chassis error was gone and I had full control over DSC and MDM. My theory is that at some point (miles, time, speed?) if you have a chassis error due to the EDC circuit you will lose the ability to turn off DSC. So if you are ever unable to turn off DSC or set MDM then check out the EDC cables.
2022 M850i
09-25-2024, 02:46 AM | #3 |
XDrive Master
Rep 1
I have the exact same problem. Today, in the rain, I thought I’d check how the G31 grips the road with the xDrive system. I turned everything off, gave it some gas, and everything turned back on. I have a "Chassis" error, the rear strut wire is damaged, and the adaptive suspension is currently stuck in standard (sport) mode. This only strengthens your theory that due to the "Chassis" error, the DSC system cannot be turned off.
