11-20-2023, 03:47 PM | #1 |
Rep 5
Spacers & how do they differ from brand to brand?
Hey all, getting my M2 next week and thinking about getting a couple of things done while my car is in the shop getting PPF'ed.
Spacers were a good place to start. How much do spacers differ from brand to brand? Why are people paying more for certain spacers over another? Trying to save money as strategically as possible while I map out my build for this car Thanks guys! |
11-20-2023, 05:39 PM | #2 |
BMW GENIUS
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
Assuming both brands offer high quality products, you will want to make sure they are hubcentric. Some do not offer that, so keep that in mind. Secondly, take a good look into material, some are made of more expensive material.
11-20-2023, 06:34 PM | #3 |
Car Geek
3626
Rep 3,593
If it isn’t made of 6061-T6 aluminium (or few less common alloys that are equivalent), then I’d run away. Any other material is not really suitable for wheel spacers. That being said, even the cheapest spacers are unlikely to use anything else less suitable than 6061-T6, as the material cost in a 15mm spacer machined from a 150mm diameter, 25mm blank is about $3 per spacer.
11-20-2023, 07:33 PM | #4 |
Rep 843
Also check spec weights. Future Classic for example you are adding less rotational weight ( the more you add, the more parasitic power loss) than others while still getting 6061-T6.
11-20-2023, 08:43 PM | #5 | |
Car Geek
3626
Rep 3,593
I would look for the spacers with consistent and high quality machining and the proper hub centric boss chamfer, above anything else. |
11-21-2023, 06:33 AM | #6 |
Rep 5
Appreciate the info, all. With that being said, what spacers would you guys go with for the G87 keeping in mind being hubcentric, made of the right material, and it isn’t too heavy.
11-21-2023, 09:03 AM | #7 |
Rep 843
For the reasons above, I went Future Classic. Hubcentric, lightest of the lot, made of the above described material. But I also only consider them a temp stop gap until light weight wheels come in to replace the oem boat anchors we get with our cars.
somer966.00 |
11-21-2023, 08:58 PM | #8 |
Rep 5
alright thats what im going with too, thanks man
