BMW M2 Forums 2023+ (G87) iDrive, Nav, Stereo, Bluetooth, Electronics
      11-23-2023, 03:28 AM   #1
baj_baj
baj_baj's Avatar
408
Mirror with a garage door opener
As the option isn't available in the g87, has someone tried retrofitting this? Is it complicated?
https://www.baum-bmwshop24.de/bmw-in...RoCDsMQAvD_BwE
      11-23-2023, 08:49 AM   #2
fangelov
The ones in the US come with one from the factory.
      11-23-2023, 11:07 AM   #3
aerobod
Car Geek
aerobod's Avatar
This is the G87 one fitted from the factory:
      11-23-2023, 12:09 PM   #4
DBV
DBV's Avatar
863
Drives: G87 M2 and more
Realized I didn't have it in my build when I picked up the car. Asked my BMW Rep and he told me it's not available for the M2 in Germany. So weird its standard in the US.
@DBV_
Current: '23 G87 M2 6MT / '18 Brabus Smart / VW Touareg (7P) Executive
Gone: '21 G20 330d / '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp)
      11-23-2023, 12:20 PM   #5
aerobod
Car Geek
aerobod's Avatar
In Canada it is not standard, but is selectable as an option:
      11-23-2023, 01:04 PM   #6
aerobod
Car Geek
aerobod's Avatar
With the electrochromic feature as well as the garage door opener, it should be this mirror: https://www.schmiedmann.com/en/cata-ol?q=51169476752#
      11-23-2023, 01:28 PM   #7
aerobod
Car Geek
aerobod's Avatar
One thing to be aware of when replacing the mirror, though, is that things such as auto high-beam and driver assistance features on a specific car can change the specific mirror required for compatibility of all the features.
      11-27-2023, 04:14 AM   #8
baj_baj
baj_baj's Avatar
408
After a lot of research, seems there are major compatibility issues between different garage doors and homelink... So even if the mirror itself can be retrofitted it won't work with my garage door because of some rolling code encryption BS
I assumed a remote is a remote and it works with every system... Nope.
      11-27-2023, 07:51 AM   #9
dmr
Drives: G87
Standard garage remote codes are too easily hacked. This added security is a good thing in general. What is described here may seem "out of reach" to most, but it really isn't that complicated:
https://www.wired.com/2015/06/hacked...doors-seconds/
      11-27-2023, 09:04 AM   #10
Smilodon
Drives: '24 M2
I won't say "I haven't had any problems", but was able to get my homelink mirrors (on prior car and the new BMW) to work with one of the latest "rolling code" garage door openers.
You need to be very careful and methodical in following the instructions on both your garage door opener and the mirror setup in the owner's manual. Everything has to be in the proper mode and you need the proper "feedback" (mostly blinking lights) from opener and mirror.
One thing that was not clear from the instructions in the owners manual was that the car itself needs to be in the correct "on not started" state for all of the mirror stuff to work as expected.
I have an older truck that has a homelink system that will NOT work with the newer openers. So, they do eventually become obsolete. They do make repeaters that will talk to the new opener on one side and the old homelink on the other.
      11-27-2023, 09:45 AM   #11
ZPD
ZPD's Avatar
720
Drives: 2022 M850i GC, 2023 G87
As an alternative, you can get a wifi controlled switch and pair it to your Amazon Alexa account. I have that on one of my garage doors so when I am driving up to the house I say, "Alexa, activate blah blah blah" and it is the equivalent of pushing the garage door button. I wish that I could say "open the garage" and "close the garage" and I could only open if the door was closed but that requires inputs which Amazon does not support.
Admittingly, there are some security concerns because theoretically someone could stand outside of my house and yell the activation words and the garage door would open but they would have to yell pretty loud and know the activation words that I selected. It also won't work if the wifi in your house is down and sometimes the Alexa app on your car is glitchy. And of course, I have no idea what Amazon Alexa features are available in your country but perhaps it is an option.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, SPL links, Adro wing, IRL exhaust, Verus Splitter, MAD downpipes, Bootmod3; IG:g87_43
      11-27-2023, 11:50 AM   #12
aerobod
Car Geek
aerobod's Avatar
We have a Chamberlain / Liftmaster rolling code garage door opener that is fairly recent and has features such as app control via Internet connectivity, autoclose, wireless keypad, etc.
The G87 homelink mirror remote works fine with it.
      11-27-2023, 12:33 PM   #13
baj_baj
baj_baj's Avatar
408
In my case it’s a building gate, if internet is to be believed it might be the only system that doesn’t work with any universal opener and homelink. Literally the only way is with an original remote. I also looked into one of those solutions that plugs into a cigarette lighter, but no luck..
      11-27-2023, 03:41 PM   #14
DomMuc
DomMuc's Avatar
Germany
692
https://homelink.com/compatible/products
you can check with choosing your remote or you know wich garagedoorsystem is used..
      11-28-2023, 06:42 AM   #15
baj_baj
baj_baj's Avatar
408
I maintain your issue might not be the home link, but your lack of access to the garage door opener.
The door manufacturer is not on the homelink compatibility list and I haven't seen one case where someone managed to pair them...
      11-28-2023, 08:30 AM   #16
islandfalconer
islandfalconer's Avatar
200
Drives: BMW M2
Pretty sure it’s the same mirror found in the X3, X4, X5 M3, you could probably find a used one on eBay and fit it. My guess would be it takes power from the same harness that already powers the mirror. In my Mini, and a few other BMW’s I didn’t have to retrofit any wiring. Just plug and play.
