BMW 2 Series Technical Topics (G42) App, Nav, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics
      11-24-2023, 05:13 PM   #1
kactussjack
Drives: M240i
USB Ports
Has anyone tried switching the data and charging port? I pretty much just use a memory stick for music and it would make a lot more sense if the data port were in the center console. It's insert and forget for 6 months and wouldn't clutter up the exposed area.
J-RO2415.50
      11-24-2023, 07:29 PM   #2
J-RO
Drives: 2024 M240ix BMW X1 28i
Used to be like this on my F44.
      12-08-2023, 09:25 AM   #3
Z_Victor1
Z_Victor1's Avatar
United Kingdom
62
Drives: 2022 G22 M440i 👍
Have you considered one of these?
https://www.westerndigital.com/produ...CZ430-512G-G46
I have the 512GB version and on it I have over 16,000 music tracks in FLAC format up to 24 bit and it works a dream
Superb playback quality and fast searching. I leave it permanently attached and it's no clutter or inconvenience at all.
Just an alternative approach should you not be able to switch.
WA63.00
Resoelg325.50
      12-08-2023, 12:32 PM   #4
WA
G42 B58 C56
WA's Avatar
Drives: 2024 M240i
Z_Victor1
I've tried a few times to do this (music via USB to improve quality over wireless) with mixed success.
The main thing I haven't been able to accomplish is Playlists. Are you successfully using Playlists and if so, what's your method/format?
Thanks.
      12-09-2023, 06:45 AM   #5
Z_Victor1
Z_Victor1's Avatar
United Kingdom
62
Originally Posted by WA View Post
Z_Victor1
Thanks.
V Good question...but I can't help, sorry as I've not tried...
I scan the albums and just jump in...have two sticks with about 1,500 albums on each.
I tried formatting a 1 TB HD into two distinct Drives (A + B) trying to 'con' the system into thinking it was two separate drives, but it then missed out on a large number of albums that would not even display.
Once I got the number of files (not tracks) down below the 16,384 (on each 512GB USB stick), it worked a dream with ALL the music playable and ALL in top quality. Others in the forum(s) seem to have had issues with 24-bit Hi-Res FLAC files, yet mine play with absolute clarity.
These threads have some info on USB sticks:-
https://g20.bimmerpost.com/forums/sh...xFAT+USB+stick
Good luck.
      02-13-2024, 07:39 PM   #6
Fronzdan
Drives: '24 M240 xDrive
Z_Victor1
Thanks.
Have you tried creating m3u files with an app on your pc? I used to create them when using memory sticks for music storage in the past. Haven’t messed with that for years but I bet that’s what the head unit would use.
      02-13-2024, 09:29 PM   #7
Resoelg
Resoelg's Avatar
Drives: 2024 M2 ZV-Blue
GREAT tip. Thank you!
      02-14-2024, 08:43 PM   #8
Fronzdan
This one is so low profile you’ll forget its there in the front port. It’s the one I got too.
      02-19-2024, 02:28 AM   #9
WA
G42 B58 C56
WA's Avatar
Drives: 2024 M240i
Good suggestion, but yes I have created/tried m3u files as Playlists, but they do not show up in iDrive8 (while Albums, Artists and Songs do.)
