12-11-2023, 04:21 AM | #1 |
Rep 4
Break-in service's effect on performance is real or myth?
Hello Everyone,
My 2000km (1200miles) break-in service is due in 1000kms. I was wondering if any of you really could feel the difference in performance between pre and past service, or it is just a BMW marketing BS? If you could describe the feeling with numbers e.g. +10-20% power, it would be most appreciated |
12-11-2023, 07:27 AM | #3 |
Primo Generalissimo
5037
Rep 4,188
Drives: All of them
Garage List 2024 Ford Bronco Ra ... [10.00]
2018 Porsche 911 GTS [10.00] 2023 BMW M2 [9.25] 2022 Ford F-250 Tremor [8.50] |
My CA alluded to this being real, but not sure if this is just something he was parroting or really knew. I think the difference is you’re trying to stay below rpm limits and a lot more power is on tap when you lay into it. Makes it seem like two different cars.
Carefree2276.50 |
12-11-2023, 07:35 AM | #4 |
Rep 106
Allegedly only if you have the drivers package, they raise the speed limiter after break-in. I didn't do any top speed runs until 2000km, so I can't confirm
deleted_807865_k0a0df9ee6877.50 |
12-11-2023, 08:00 AM | #5 |
Rep 1,498
Agreed. I was very careful with the 1200 mile guideline. Recently (>1500 miles), I’ve put my foot heavy into the pedal and, damn, it feels like 2 different cars. The car is a monster. YMMV
12-11-2023, 08:18 AM | #6 |
Rep 38
There’s been multiple threads on this where BMW technicians have confirmed all they do is change the engine oil and filter, and diff oil.
They don’t unlock the higher top speed (if the driver’s pack is optioned), they don’t unlock ‘launch control’, they don’t unlock higher RPM within the engine. You can do all of the above from the moment you drive off the forecourt if you want, it’s just not advised or part of the ‘running-in procedure’. |
12-11-2023, 08:40 AM | #7 | |
Rep 3,655
I have trouble believing this to be true. I assume that is controlled by the ECU and that would mean the dealership would be unlocking the ECU...and that is not happening. |
12-11-2023, 08:41 AM | #8 |
Rep 987
Fluid and filter change. But gives the green light on the right foot so that's the performance difference
12-11-2023, 11:52 AM | #10 |
Rep 38
Nice video and great to see the whole process and get the explanation behind everything.
Shame you didn’t show the tech updating the car with the BMW software as he said he would explain more about this. I’m still not convinced on the power being held back in ‘run-in mode’. Keep up the videos! |
12-11-2023, 12:24 PM | #11 | |
Rep 299
12-11-2023, 01:55 PM | #12 |
Rep 1,236
12-11-2023, 02:04 PM | #13 |
Professor
4268
Rep 2,851
I can't tell you if there is anything from a performance improvement standpoint. The SA told me they finished the fluid changes and were just "finishing up the new programming" when I was waiting to pick it up. I also noticed on my paperwork they replaced the rear diff "screw plug with o-ring" though the tech in the second video said that was not necessary.
12-11-2023, 02:06 PM | #14 |
Rep 1,236
Because I have the M drivers package and spoke with many M-Tech’s I know around town about it, as well as inquiring to BMW N.A. Online about it via email.
The only thing they do at service is what you see in video above. Specifics of what you order on the car are done in-factory. I did not take my BMW M2 to the same dealership I bought it from, I can imagine some dealerships not doing the “de-limiter” on accident if this were the case. Every de-limit drivers package tune is done via software straight from SLP Mexico plant for the M2. |
12-11-2023, 02:13 PM | #15 | |
Rep 1,236
12-11-2023, 02:14 PM | #16 | |
Rep 1,236
c1pher5037.00 |
12-11-2023, 02:15 PM | #17 |
Rep 222
According to this (which is questionable) at ~9:30 there is PDI (delivery mode) and then "running in mode" for M cars that is in fact restricted. And then unrestricted after run-in mode. That is contradictory to what I understand to be true. Odd.
12-11-2023, 02:18 PM | #18 |
Primo Generalissimo
5037
Rep 4,188
Drives: All of them
Geighty72691.50 |
12-11-2023, 02:26 PM | #19 |
Rep 352
Drives: 2023 M2
There has been a lot of conjecture about RIS and RIS specific lubricants (engine and diff). There is absolutely no proof one way or the other.
There is no reason to believe that the speed limit unlock couldn't be done automatically if there was a lock at all. I do agree that dealers are not likely to be the ones to change this setting but they do reset the service interval with the RIS. Personally I don't see the issue other than as a debate. It's your car, drive at 178 mph with 100 miles on it if you want. Same with an early oil change or whatever - your car, your warranty issues or long term ownership issues. The manual calls for run-in service, why not do it as prescribed. For those that believe it is German overengineering need to look no further than the Corvette C8 which increases RPM limit and top speed with miles during its breaking. BMW could have done it that way but chose to not. Anyway.
2023 M2
2014 Triumph Trophy |
12-11-2023, 02:35 PM | #20 | |
Rep 299
12-11-2023, 02:49 PM | #21 | |
Rep 3,655
Stating its questionable is being kind...I call flat out Bull $hit. The video is done "after hours" at BMW, and not an authorized BMW video. There are "special" break in fluids. Oh, best is the beginning that its sponsored by some cf co.pany that makes phone cases? Seriousy? I really didn't need to watch any further and lose any more time out of my life. |
CadolinaRipr444.00 |
12-11-2023, 02:54 PM | #22 |
Rep 1,236
All I know is IF letting the car go in the future or trading in for a new model down the road…M Drivers Package will help retain value. I don’t ever plan on topping 135mph even on track, but it’s nice to know we have more in munitions in the armory!
