12-13-2023, 10:33 AM | #1 |
Professor
4210
Rep 2,829
Issue with universal garage door opener
Tried programming the universal garage door opener to my garages and my driveway gate yesterday. I successfully programmed my 330e and X3MC, but didn't have much luck with the M2. Got the green light that indicates programming was successful, but then it would only close my garage door, not open, and it would open my driveway gate but not close it?
I reset the buttons and reprogrammed multiple times with the same results each time. Any thoughts? Garage door openers: Genie w/Intellicode installed 2017 Driveway gate opener: Mighty Mule
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo full Merino interior.
His: '23 M2, Toronto Red Metallic, M highlight interior. '11 Callaway SC652 Carbon Edition Corvette Z06. Inferno Orange Metallic. 1 of 3. |
12-13-2023, 07:32 PM | #2 |
Rep 198
You probably have a rolling code. Look up "garage" in there I drive manual, you'll need to use different instructions. Try using buttons 1 and 3 for door and gate vs 1 and 2.
12-13-2023, 07:48 PM | #3 |
Professor
4210
Rep 2,829
I followed the instructions for rolling code, just like I did in the other two BMWs and those work as they should. I need to use all 3 buttons (2 garage doors & 1 gate). I'll mess around with it again tomorrow & see if I can get it to work properly.
12-14-2023, 06:18 AM | #5 |
Rep 167
Drives: 2023 BMW M2
I just went out to the garage to test this, and I had the same problem, I had to hold the buttons longer to re-program them, way longer than the green light stays on for.
After shutting my car off I lost all the programing, so I did it again and only one decided to work. After trying 2 more times I got it to work and stay working but you have to hold the Homelink button on the mirror and the door remote at the same time for quite a while for it to take and store. I also reset the Homelink by holding the two outer buttons, 1 and 3, on the mirror to reset the programing before trying again each time again, maybe that helped too? |
12-14-2023, 09:16 AM | #6 |
Rep 2,207
Drives: 2024 M240ix BMW X1 28i
My problem was not getting it to work but the range. I have to practically be in the driveway. My wife's Santa Fe works from the middle of the block.
12-14-2023, 11:04 AM | #7 |
Car Geek
4253
Rep 3,902
I found the range on our M2 garage door opener is very good, typically about 100 to 150m compared with 50 to 100m for our Macan. By the time I drive on to the driveway, the door is open.
12-14-2023, 03:39 PM | #9 |
Rep 358
I have a Mighty Mule gate opener and a Genie garage door opener. On both of my BMW's I have no problem opening the gate (as long as I am close) and I can always close the garage but opening the garage only works 1/2 of the time. Frustrating.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Goodyear 3R, SPL links, Adro wing, IRL exhaust, Racechip, Verus Splitter; IG:g87_43 |
Baller198.50 |
12-15-2023, 09:20 AM | #10 |
Professor
4210
Rep 2,829
Not that I'm aware. I cleared the programming on my last BMW before trading it in. I've gone through the clearing all buttons and reprogramming the buttons multiple times now. Each time I get the green light indicating programming was successful (per the manual), but it still only closes the garage doors and opens the gate (I have to hold very long before it works) but doesn't open the garage or close the gate
12-18-2023, 10:32 PM | #11 | |
Rep 198
12-18-2023, 10:48 PM | #12 | |
Professor
4210
Rep 2,829
12-20-2023, 04:16 PM | #13 |
Professor
4210
Rep 2,829
I got both garage doors and the gate programmed today, and the mirror buttons appear to be working consistently. What I had to do was follow both the non-rolling code and rolling code instructions from the manual in sequence.
I reset all buttons, hit button 1 - slow blinking orange. Held remote up to the mirror and held the button down until I got fast green blinking. Then my son hit the program button on the garage door opener and waited for it to start flashing purple. I then held the mirror button down for 3 second & repeated 3x until it operated my garage door. Repeated these steps for my second door & it works the same. With the mighty mule gate I hit the mirror button - slow flashing orange. Then held the remote up to the mirror and pressed the button. The mirror immediately turned solid green. The mirror button will open/close the gate but will not operate the gate if pressed again immediately. It takes 3-4 more attempts or waiting at least 1 minute before it will operate the gate again. That's a little frustrating as I generally open it as I'm pulling up to it then immediately close it when I drive through. The Homelink transmitter in my Z06 allows me to do this, and also in my wife's '22 X3MC. |
deleted_807865_k0a0df9ee6877.50 |
