      12-16-2023, 03:21 PM   #1
turnsignalslol
turnsignalslol's Avatar
Drives: '24 G87 M2
High pitched whine noise cold start
Here’s a video of another guy who has the same issue: https://www.reddit.com/r/BMW/s/HXXCVXzEe7
I started my car this morning and heard that whine and was wondering what it was and most importantly, if it’s normal. Seems to only happen on cold start, but I don’t really remember it happening before.
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD
2020 M2 Competition DCT
      12-16-2023, 04:13 PM   #2
kyrix1st
kyrix1st's Avatar
2430
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
I'm assuming you are not talking about the starter motor crank.
It is very common for M engines, new or old, to make this noise especially when it is cold outside. I suspect it's a combination of increased vibration from the reinforced engine mounts and chassis, and louder injectors and secondary air pump due to the colder weather.
Pass me if you can.
      12-16-2023, 04:54 PM   #3
turnsignalslol
Drives: '24 G87 M2
Yeah I’m talking about when the engine fires up, there’s a whine sound. So it’s normal?
Past: 2022 330i RWD
      12-16-2023, 05:23 PM   #4
Shadak
Shadak's Avatar
84
Drives: M2 G87
I had this once or twice, it didnt seem to cause anything and it went away immediately after start so I assume not much to worry about unless its every cold start.
      12-16-2023, 10:50 PM   #5
Searay55555
Searay55555's Avatar
381
Drives: 2012 335is Convertible
Mine sound ls exactly the same way every time.
      12-16-2023, 10:54 PM   #6
FrankWhite!
Drives: BWM G87
Same. Nothing to worry about. Belts turning and turbos winding.
      12-16-2023, 11:04 PM   #7
turnsignalslol
Drives: '24 G87 M2
Asked a friend, he says it could be due to our ACs starting up as soon as we turn the car on? Either way I don't think it's a big issue
Past: 2022 330i RWD
      12-17-2023, 10:08 AM   #8
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
Easy enough to eliminate the A/C. Turn it off before engine start.
Sounds like normal accessory drive noise. But if the A/C is on the additional load the compressor places on the accessory drive could make the noise worse.
      12-21-2023, 07:40 AM   #9
turnsignalslol
Drives: '24 G87 M2
Same here, every cold start after letting the car sit overnight and it makes this noise. As long as everyone else has it I'm not worried lol
Past: 2022 330i RWD
      12-21-2023, 07:41 AM   #10
turnsignalslol
Drives: '24 G87 M2
The AC doesn't turn on when you unlock the car/turn on the ignition, it does it upon starting the engine automatically. Is there an option in iDrive to turn this off?
Past: 2022 330i RWD
      12-21-2023, 09:09 AM   #11
RockCrusher
If the A/C compressor is left on when the car is parked and the engine shut off the A/C compressor is on as soon as the engine starts.
But I don't leave the A/C compressor on. My SOP is to a few minutes before reaching my final destination of the day I use the climate control button to call up the climate control screen and slide the A/C compressor to OFF.
Upon the next use of the car I start the engine and if A/C is needed turn on the A/C compressor via the same climate control button/screen.
      12-21-2023, 01:12 PM   #12
turnsignalslol
Drives: '24 G87 M2
I also turn off the ac before turning off my car, yet it turns back on automatically.
Past: 2022 330i RWD
      12-21-2023, 01:35 PM   #13
turnsignalslol
Drives: '24 G87 M2
Yes.
Get in the car, push the start button three times without stepping on the clutch or brake pedal.
Your fan will start. Assess noise.
Enter the climate menu and turn off the climate functions. Your fan should stop.
Turn on the car. Assess noise.
Is the “turn off climate functions” option the key to making the car not turn on the AC automatically? I’m leaving in about an hour so I’ll report back if I hear the noise with this option checked.
Past: 2022 330i RWD
      12-21-2023, 01:40 PM   #14
turnsignalslol
Drives: '24 G87 M2
That’ll turn off the whole system (which includes the AC compressor).
If you want the fan to continue, I believe there’s an option to turn off just the AC and keep the fan on.
So do I have to manually turn on the AC every time I want it on?
And no, I don’t want the fan on, I want the whole system to not turn on automatically upon start up and would prefer for it to turn on when I actually want it to lmao
Past: 2022 330i RWD
      12-21-2023, 01:48 PM   #15
turnsignalslol
Drives: '24 G87 M2
As you mentioned, the ac will always be turned on when you turn the car on.
I was describing steps to turn it off so you can assess the noise in different circumstances to determine where your noise comes from.
Yeah I’m going to try your specific method out later when I leave.
I’m just wondering why it starts the fan automatically in the G chassis, this didn’t happen on the F chassis
Past: 2022 330i RWD
      12-22-2023, 01:40 AM   #16
turnsignalslol
Drives: '24 G87 M2
I forgot to click the turn off climate functions button when I started the car so I'll try again tomorrow
Past: 2022 330i RWD
      12-22-2023, 06:33 AM   #17
turnsignalslol
Drives: '24 G87 M2
BMW automated everything in this car. Headlights, climate, heated seats. It’s annoying but it is what it is…
Kind of bummed you can't turn off the lights while the car is in motion. Not that I'd need to but I just think going "ghost" looks kind of cool when recording a roller lol
Past: 2022 330i RWD
      12-22-2023, 07:59 AM   #18
RockCrusher
That's not behavior I recall seeing. My M2 is a 2023 model. Your M2 is a 2024. Could be this behavior is "new" with 2024 model?
      12-22-2023, 08:13 AM   #19
turnsignalslol
Drives: '24 G87 M2
Honestly not sure, but it's quite annoying! I'd like my car to not start with the AC or the fans on but turn on when I enable climate control please -_-
Past: 2022 330i RWD
      12-22-2023, 08:33 AM   #20
Shadak
Shadak's Avatar
84
Drives: M2 G87
my 2023 M2 (EU) starts with no AC if I didnt have it on before shutdown ,that setting seems to be always remembered.
      12-22-2023, 12:33 PM   #21
KC87ZB
KC87ZB's Avatar
443
Drives: 2023 M2
2023 BMW M2  [10.00]
... Like the heated seats you can no longer choose a temperature for them to come on, as apparently the car automatically chooses for you.
I wonder if you code higher temperature settings for the seats if that impacts the temperature at which they will automatically turn on for that setting? I have no idea, just guessing here. I would like them to come on when i request and just modulate to the setting temperature; so annoying.
2023 M2
2014 Triumph Trophy
      12-24-2023, 06:27 AM   #22
turnsignalslol
Drives: '24 G87 M2
Turned off all the climate control stuff in diagnostic mode, still made the Hellcat supercharger noise upon cold start. Whatever causes it is beyond me
Past: 2022 330i RWD
