12-17-2023, 02:15 PM | #2 |
Rep 7,542
Have you checked your owners manual to see how to operate the rear washer jet (if it is optioned)? That may help you find out where it is located.
See #8 in the diagram from the parts database below: EDIT: see instructions below from the X3 owners manual…which should be very similar (since it the same instructions for my X5). Again, check your owners manual (or use the manual embedded in idrive)…if you initiate the rear washer…does it activate…or can you hear the pump attempt to disperse washer fluid?
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-17-2023 at 03:34 PM.. |
12-17-2023, 03:46 PM | #3 |
Rep 7,542
BTW…of the approx 50 or so other viewers of this thread…are any of you X1 owners that can quickly verify/clarify any of the above?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
12-18-2023, 12:18 PM | #5 |
Rep 631
Drives: 2018 F48 X1 xDrive 18D
12-25-2023, 10:22 AM | #6 |
Rep 7,542
Looks like we may not get a resolution from the original poster. Another one-and-done ghost post.
Thanks to those that confirmed the rear washer jet’s location.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-25-2023 at 10:38 AM.. |
