12-23-2023, 05:25 PM | #1 |
Rep 65
Aggressive Track Fitment Guide - 19x11 305 Square
I primarily use this car as a weekend fun car/Autocrosser and wanted to run a 305 square setup without pinching a 305 on a 10.5 wheel. I've seen a 19x11 run but there wasn't too much definitive info on it and after a bit of research, I pulled the trigger on a set of Apex VS5-RS in Motorsport Gold as part of their Black Friday sale. I hope this info helps others in their wheel/tire search and is a good base for an initial track alignment.
Wheels Apex VS5-RS 19x11 ET22 12mm Spacers all around Tires Falken RT660 305/30R19 Sqaure Suspension M Performance HAS - Mostly all the way down besides adjustments to corner balance. Millway Race camber plates Alignment Front -3.3 deg camber 1mm toe out Rear -2.1 deg camber 2mm toe in Clearance This barely touches the fender liner at full lock and doesn't catch. I would slightly trim or apply heat and bend the fins a little. The strut barely clears and I would say this is about the most tire you can get up front on this setup without adding spacer and rolling/pulling fender. As a note, the RT660 is probably going to be the widest tire within a given section width in the 200tw category. The rear has no issues clearing whatsoever. Last edited by Sherlock997; 12-25-2023 at 07:37 PM.. |
12-23-2023, 06:37 PM | #2 |
Rep 249
Drives: M2 G87 Brooklyn Grey
Looks nice. Really like the wheels on the BG. One day…
Sherlock997218.50 |
12-23-2023, 07:16 PM | #3 |
Rep 260
Looks good. Are the RT660's directional?
Check the struts after a few track days. I had about a 5 mm gap between my 295's and struts while stationary but I started to see signs of rubbing from tire flex on corners.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
Sherlock997218.50 |
12-24-2023, 01:37 PM | #4 |
Rep 65
Thanks! Yes they are directional but there is no inside/outside specification meaning they can be flipped by mounting them to the opposite side wheel. I'm going to keep an eye on the strut to see if I get any rubbing but i can fit a credit card in there and am hoping the tire flex is minimal on a 30 sidewall.
12-27-2023, 08:36 PM | #6 |
Rep 65
The additional tire really helps the turn in and there is no more understeer on corner exit. The steering is a bit heavier with such a wide tire but overall I feel like the car is more agile and responsive with the alignment changes and additional grip. The car settles into a corner beautifully now and feels so satisfying when you get it just right.
01-12-2024, 02:42 PM | #8 |
Rep 65
04-07-2024, 05:45 PM | #10 |
Christmas Poo
1029
Rep 1,179
Dammit....I might need to add camber plates to the to do list now . Looks great. Any side-shots of your car in daylight? Want to see the gold against the BG from the side in uncolored light.
Read...no drive, the manual. |
04-09-2024, 08:17 PM | #11 | ||
Rep 65
Mr. Hankey1028.50 MineralGreyMetallic642.00 |
04-15-2024, 08:39 AM | #12 |
Rep 41
Glad to hear. Waiting on mine to arrive now ha
Sherlock997218.50 |
